Gettin a tune up anything you would do different
Old Sep 22, 2007 | 08:59 AM
zoso's Avatar
Default Gettin a tune up anything you would do different
Ok so i have a 2000 civic ex with I/H/E and its time for me to get a tune up, this is the stuff i was going to use. Let me know if you would do it a different way. The ones that have 2 what one is better with my set up...
Fuel filter- AEM (is it worth the money???) OR OEM?
Spark plugs- Already bought NGK plugs...
Spark Plug Wires- NGK OR OEM?
Dis cap and rotor-OEM?
adjust/pcv valve-OEM?
I think that is all i should need. And my car should finally run fine... Thanks so much guys!
Old Sep 22, 2007 | 09:03 AM
posHonda's Avatar
get the oem parts
have you done the timing belt and water pump?
Ron454321's Avatar
I would just buy what the local auto store has, ends up being cheaper for you. By run fine what do you mean, you are having issues now?
Old Sep 22, 2007 | 09:17 AM
zoso's Avatar
Default Re: (Ron454321)
yes i did timing belt. My idle is a little ruff, i just changed my oil too.
Old Sep 22, 2007 | 09:24 AM
zoso's Avatar
Default Re: (zoso)
OBX fuel filter is only 5 bucks more than OEM...
Old Sep 22, 2007 | 10:46 AM
b 1 6 a 2's Avatar
Default Re: Gettin a tune up anything you would do different (zoso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zoso &raquo;</TD></TR><TR><TD CLASS="quote">Ok so i have a 2000 civic ex with I/H/E and its time for me to get a tune up, this is the stuff i was going to use. Let me know if you would do it a different way. The ones that have 2 what one is better with my set up...
OEM Everything.
On top of these items, you're also missing key ingredients; fluids.
Oil Change.
Get your transmission fluid flush and swap for fresh OEM MTF. This is a must for every 15k miles, I beleive, but I don't follow this rule, and I do it a bit after.
Radiator flush, if never performed
Power Steering Flush, if never changed in the car's life.
OEM DOT3 Hydraulic Fluid replace, if 5-speed, if required and dirty.
OEM DOT3 Brake Fluid Bleed and replace, if required, and dirty.
It doesn't hurt to use SEAFOAM through the intake manifold's vacuum source, while spraying the throttle body with a cleaner; I use Valvoline TB cleaner; make sure you use old plugs for this option, then install new plugs.
I got all the stuff I mentioned above changed and replace a few weeks back; drives like a champ!
Old Sep 22, 2007 | 11:35 AM
zoso's Avatar
Default Re: Gettin a tune up anything you would do different (b 1 6 a 2)
so if i bought all the stuff and took it to a shop to have it put in you think it would be cheaper than just getting evrything with them. I get 30% off honda parts too by the way. Oh and i need a shop to put it in so i can show that is was done. So when i sell my car i will have the records... Thanks for the help yo
Old Sep 22, 2007 | 01:30 PM
stock_honda_coupe's Avatar
If you get parts at 30% off, get them yourself. A shop is going to mark them up before selling them to you.
Old Sep 22, 2007 | 01:52 PM
ifIexplode's Avatar
You dont flush honda transmissions.
Old Sep 22, 2007 | 02:35 PM
Default Re: (ifIexplode)
Many people stiil call it a flush, even though its just a drain/refill.
Old Sep 22, 2007 | 02:45 PM
cimo463's Avatar
oem plug wires/cap/rotor is NGK just is not marked NGK
Old Sep 22, 2007 | 02:53 PM
b 1 6 a 2's Avatar
Default Re: (stock_honda_coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stock_honda_coupe &raquo;</TD></TR><TR><TD CLASS="quote">Many people stiil call it a flush, even though its just a drain/refill.</TD></TR></TABLE>
Yes, that's what I meant. The word "FLUSH" seems to linger, when it's dain and fill.
nikesb4dub
Oct 12, 2013 08:03 AM
JDWago
Jun 2, 2013 07:39 PM
NHcuban
Apr 3, 2009 11:30 PM
DarkCyde SI
Jun 22, 2006 10:53 AM
ho9984
Apr 28, 2005 07:43 PM
