high Z vs low Z: how important is the resistance of the injectors?
Old Sep 21, 2007 | 05:15 PM
garados's Avatar
Default high Z vs low Z: how important is the resistance of the injectors?
I need high impedance injectors for my car. Unfortunately, the set I just bought are low impedance. I'm going to put in resistors into the legs of the injector plugs.
Now, the stockers are 13.6 ohms, the ones I have now are 1.9 ohms. The easiest way to do this would be to do a 10 ohm and a 1 ohm resistor in there and call it a day ... hoping that 12.9 ohms would be good enough On the other hand, if I do a combination of 10's, 5's, and 1's, I can get it to just under 13.7 ohms.
Should I even sweat getting it to 13.6ish or would 12.9 be alright?
Thanks for the help
Old Sep 21, 2007 | 09:43 PM
ndogg's Avatar
Default Re: high Z vs low Z: how important is the resistance of the injectors? (garados)
you will be ok with just the 10 ohm ones for 11.9 total.
Old Sep 21, 2007 | 09:56 PM
eastbay92cx's Avatar
You may know this, but if you are going to use single resistors instead of a factory resistor box from a different car, you probably want to go with the 10watt ones, rather than 1/4 watt ones for ex.
As in more like these:
http://www.kelvin.com/Merchant...CRS10
and not these:
http://www.opamp-electronics.c...=1041
They have them (the first ones) at radio shack. $1 a piece come in packs of 2.
slowwcivic
May 4, 2011 06:22 AM
Scheizty
Dec 16, 2007 06:49 PM
96vtecI4
Feb 18, 2007 06:26 AM
ppfalcon
Mar 29, 2006 11:53 AM
dkdjlf
Sep 19, 2003 02:31 AM
