Low vs. High Impedence
Old Dec 16, 2007 | 05:05 PM
Scheizty's Avatar
Default Low vs. High Impedence
On a bb6 with hondata s300, will I need a resistor box for larger injectors, or are the stock injectors also low impedence? I have also read that h22 harnesses already have resistor boxes. Is this true or will I need a resistor box?
Old Dec 16, 2007 | 05:17 PM
laocivic's Avatar
Default Re: Low vs. High Impedence (Scheizty)
preludes have resistor boxes already..u just use high impedence peak and hold injectors.
low inpedence are saturated injectors like on civic and tegs.
just use w/e you want but make sure its high impedence/peak and hold not saturated
Old Dec 16, 2007 | 05:21 PM
Scheizty's Avatar
Default Re: Low vs. High Impedence (laocivic)
If they have resistor boxes, then that would mean that I can use low impedence, peak and hold, correct?
Old Dec 16, 2007 | 05:33 PM
DA_HONDA_BOY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by laocivic &raquo;</TD></TR><TR><TD CLASS="quote">preludes have resistor boxes already..u just use high impedence peak and hold injectors.
just use w/e you want but make sure its high impedence/peak and hold not saturated</TD></TR></TABLE>
high impedence is not peak and hold!!! high impedence injactors come in the civic and tegs
low impedence injactors is peak and hold and low impedence injactors need a resistor box
Old Dec 16, 2007 | 05:55 PM
Scheizty's Avatar
Default Re: Low vs. High Impedence (DA_HONDA_BOY)
I found some goodies...
http://www.robietherobot.com/s...e.htm
I actually tested the injectors --
The aftermarkets were ~ 3ohm
The stock injectors were ~12 ohm
Old Dec 16, 2007 | 06:49 PM
laocivic's Avatar
whoopsss i sed that backwards..sorry but yea
Steeve_Civic
Dec 4, 2011 10:11 AM
columbushatch
Jan 17, 2009 11:08 AM
DrivinVtec
Sep 17, 2007 10:08 AM
the.hamburglar
Aug 12, 2007 07:41 PM
96vtecI4
Feb 18, 2007 06:26 AM
