Bogging issue getting worse. Searched.
Old Sep 21, 2007 | 01:56 PM
es_squared's Avatar
Default Bogging issue getting worse. Searched.
Did a search but nothing that sounds like my situation.
A few days ago my car started to have a slight bogging issue, first it would come and go, then last night it got pretty bad. I basically cant give it any throttle, I can give it only a bit without it bogging, but anymore than like 5-10% throttle itll start sounding like a boat. Bogs at idle as well, but fluctuates from normal to bogging.
Any ideas? This morning i found moisture when i took out the ign wires so im letting it dry out, ive also been told it may be an injector, or IACV?
PS. This started to happen after i got my p28/hondata installed, after **** got worse, i put the stock ecu back and the problem is just the same, so couldn't be that.
Old Sep 21, 2007 | 02:28 PM
95silverluder's Avatar
Default Re: Bogging issue getting worse. Searched. (es_squared)
you might want to check your timing. mine did the same thing and it turned out to be my exhaust cam not lined up with my timing belt.
Old Sep 21, 2007 | 07:00 PM
russlan44's Avatar
Default Re: Bogging issue getting worse. Searched. (95ludeRiDeR)
you know there was a tread i havent seen here for a while i think it was WhiteBB2 how made it, it was about **** whats that thing called ah your out of luck with me tonight i got no energy to think. someone help
Old Sep 21, 2007 | 10:26 PM
roller3804's Avatar
Take your injectors out to make sure they are not clogged. Water down in the spark plugs will cause it to misfire. Make sure its good and dry down there.
Old Sep 21, 2007 | 10:51 PM
xxmastermindxx's Avatar
Default Re: Bogging issue getting worse. Searched. (russlan44)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by russlan44 &raquo;</TD></TR><TR><TD CLASS="quote">you know there was a tread i havent seen here for a while i think it was WhiteBB2 how made it, it was about **** whats that thing called ah your out of luck with me tonight i got no energy to think. someone help</TD></TR></TABLE>
cleaning egr related parts might be what you were thinking of
Old Sep 21, 2007 | 11:00 PM
dagle's Avatar
Default Re: Bogging issue getting worse. Searched. (xxmastermindxx)
IACV might do that, def dont rule anything out yet. when my IACV was going nuts it would bounce very slightly between 1000-1100 RPM, when i added throttle the RPMs wouldn't go up, until i reached 20-30% and it just leaped to 4-5k.
Old Sep 22, 2007 | 12:08 AM
MilanoLude's Avatar
Check your plugs, if you haven't already done so. Make sure they don't look like this.
It's possible that the moisture you have found is causing some arcing, which may have damaged your plugs and/or wires.
Old Sep 22, 2007 | 09:42 AM
es_squared's Avatar
Default Re: Bogging issue getting worse. Searched. (MilanoLude)
Thankfuly it was the moisture on the ign wires and plugs. Thanks for the input though guys. Yea Ill probably need to change the plugs too.
Old Sep 23, 2007 | 11:36 AM
es_squared's Avatar
Okay turns out the issue isn't fixed. The moisture is back, its smelled like coolant, but when i spoke to my mech he said its near impossible for coolant to get in the holes where the spark plugs/ign wires are. So if its oil, you think ti may be the rubber seals for the valve cover?
Old Sep 23, 2007 | 01:35 PM
es_squared's Avatar
up needs input on my post above pleeease
import-tooner
11
Jan 6, 2014 05:28 AM
StevenGunn
Nov 21, 2010 03:23 PM
freakasis
Feb 24, 2007 01:27 PM
forgetthestreets
Feb 15, 2007 03:13 PM
ProjektR
Jul 25, 2006 10:09 AM
