Is it true....
Old Sep 21, 2007 | 11:17 AM
HondamanXxX's Avatar
GO GIANTS!
Default Is it true....
Is it true if you mis shift, like 2nd to 5th, you can mess up your 3rd gear syncro's? Everytime I pass 4,500 RPM and shift into 3rd it grinds. Even if I do it slowly. Yes the pedal is to the ground and no I don't slam the gears. I have only went into 5th from 2nd once and that was because of a shift linkage problem but thats fixed now.
I did by some Gunk TrannyMechanic. Says helps harder shifters and what not.
Old Sep 21, 2007 | 12:23 PM
hatchling37's Avatar
Default Re: Is it true.... (HondamanXxX)
Well, if you did it only one time, it wouldn't have caused that much damage. Your 3rd gear synchro is going out. Your dog teeth are probably worn down to **** and that's why the synchros can't equalize gear speed when you shift. Time for a rebuild
Old Sep 21, 2007 | 04:39 PM
GO GIANTS!
Default Re: Is it true.... (hatchling37)
Freaking thing is new from
Modified by HondamanXxX at 8:49 PM 10/6/2007
Old Sep 21, 2007 | 06:17 PM
Dogginator's Avatar
Daisy... Daisy...
Did you change the transmission fluid?
Old Sep 21, 2007 | 06:19 PM
GO GIANTS!
Default Re: Is it true.... (Dogginator)
Replaced it with what Honda told me to put in it.
Old Sep 21, 2007 | 06:25 PM
Dogginator's Avatar
Daisy... Daisy...
I would try Honda MTF. Which transmission is this? Did honda sell an LSD transmission in the US?
Old Sep 21, 2007 | 06:27 PM
GO GIANTS!
I think about that a lot. Can't really think about anyone out there. Its a JDM Tranny with JDM B18C. Honda said they use 10w-40 on all there LSD trannys. I didn't think it was thick enough.
Old Sep 21, 2007 | 06:33 PM
Dogginator's Avatar
Daisy... Daisy...
Acura puts Honda MTF into the ITR transmission with the same LSD as the JDM SiR with LSD. That very well could be your problem.
Old Sep 21, 2007 | 06:34 PM
GO GIANTS!
Worst nightmare came true. Mad depressed right now. Thank you for your help. Now gotta buy Honda MTF
SVOHK
Nov 11, 2014 09:00 AM
eMpAtHy
Jan 22, 2009 10:42 AM
sdr85
Dec 6, 2007 11:54 PM
Kowalske
Honda Civic (2001 - 2005)
Dec 4, 2006 11:44 AM
JDM4DRACCORD
May 23, 2005 09:03 AM
