90-93 DA maplight in EG. Asking for help from BlueIntegraBoy
Open up the cover. What are the wire colors? Can't tell what color is the other wire. Red and...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JayKayNidas »</TD></TR><TR><TD CLASS="quote">So would this involve soldering? like in the 94-01 type?</TD></TR></TABLE>
I would recommend soldering all connections, but not required. Can you use female spade connectors for inside the plug? If not, cut the plug off and extend those wires. Ground the black wire to the visor screw. Extend the red wire to the power wire running along the a-pillar.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JayKayNidas »</TD></TR><TR><TD CLASS="quote">So in your DIY...green was the ground?..and the red with female was the power?</TD></TR></TABLE>
Yeah, I used green cuz I didn't have black wire.
Ten-four captain. Well I guess I will plug in that white clip...then like you said run the black to visor screw and then the power along the a-pillar and go from there...thanks man!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JayKayNidas »</TD></TR><TR><TD CLASS="quote">Ten-four captain. Well I guess I will plug in that white clip...then like you said run the black to visor screw and then the power along the a-pillar and go from there...thanks man!</TD></TR></TABLE>
Hey, the other plug, the wires are black and white/blue? Perfect. Plug that into the map light plug. Black, obviously ground and white/blue connects to the other white/blue in the a-pillar.
Yes they are as you said. So I connect plug...lead the black wire with some more black wire to visor screw with ring terminal crimped on end...ring terminal is those circular things right? That come in the combo packages of male and female connectors. Then just splice the white blue along the a-pillar...attatch the white blue form maplight to the one in a-pillar...and thats it? No messin' with fuses or nothing?
-iLLuZioN-B18C1
Oct 25, 2009 05:50 PM
raidacaipo
May 12, 2008 08:07 PM
red1997civic
Dec 25, 2003 12:50 PM
