VTEC Solenoid Code 21 CEL...bad VSS connection?
I have awesome grounds all over the battery and engine, including one on the VTEC solenoid itself. I also did the classic VTEC solenoid check of putting it to a 12V battery, and it did indeed click everytime. Before I swapped the tranny, the CEL would come on only when the engine was cold normally, occassionally on long trips. It didn't come on the first week after the tranny swap. Now it comes on all the time, warm, cold, whatever. I was told to check the VSS plug, the car has a mechanical VSS, so where is this connection? I assume it's between the Instrument Panel and the ECU, so is it somewhere behind the dash?
VSS- vehicle speed sensor. It is mounted on top of transmission by where the speedo cable goes too. There is a bolt securing it in place. It either speedo cable is not secure with the special key or the VSS is faulty.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Amir909 »</TD></TR><TR><TD CLASS="quote">
NO. Don't do this to get your stupid post count up, you need to read the TOS.
https://honda-tech.com/zerothread/2086185
</TD></TR></TABLE>NO. Don't do this to get your stupid post count up, you need to read the TOS.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wiZCo »</TD></TR><TR><TD CLASS="quote">
I dont think he did that intentionally to get his post count up. Sounds more like thats what you used to do. Youre an idiot, get a life, chill out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by atarigamer01 »</TD></TR><TR><TD CLASS="quote">
I dont think he did that intentionally to get his post count up. Sounds more like thats what you used to do. Youre an idiot, get a life, chill out.</TD></TR></TABLE>
or he didnt want to see that guy do it in every thread
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .Grimace »</TD></TR><TR><TD CLASS="quote">
or he didnt want to see that guy do it in every thread</TD></TR></TABLE>
and Im supposed to care because...?
It turns out the VTEC solenoid itself had an intermittent connection, hence the intermittent failures. I replaced it with another B-Series VTEC Solenoid, and everything is solved. The bad one still passes all the tests with the 12V battery, and the filter is clean.
aragorn1023
Aug 12, 2007 11:11 PM
DA_JDM
14
May 30, 2007 08:40 AM
