Need some help with a ghostly problem.
Old Sep 20, 2007 | 09:20 AM
Hondaciv95VX's Avatar
Default Need some help with a ghostly problem.
1995 Honda civic VX stock, 205k miles, 5 speed.
Runs and starts fine, EXCEPT for when it RAINS. When it rains, about 85% of the time it will not start. It will just crank and crank, but wont turn over. When it gets dry outside, 99% of the time fires right up, idles rough for 3-8 seconds then runs fine. Ive tried starting fluid, and changing my plugs, and checking my dizzy for water/residue. Plugs look good still, dizzy appears to be dry. I was planning on getting a new dizzy, but don't want to if that is not the problem.
Any Ideas would be GRAND.
Old Sep 20, 2007 | 10:08 AM
monicle's Avatar
Default Re: Need some help with a ghostly problem. (Hondaciv95VX)
oem hood? any chance water is getting directly to the motor when its raining?
Old Sep 20, 2007 | 10:12 AM
THEDirtyDseriesWOOT's Avatar
sounds like its leaking into the cab maybe onto the main relay ..
Old Sep 20, 2007 | 11:06 AM
Default Re: (THEDirtyDseriesWOOT)
is OEM hood. But I was not driving during the rain, it was sitting. and it is for the most part 100% dry under the hood. dry under the hood.
Main relay is on the passenger side of the dash, correct? Ive smacked the dash a few times, but with no luck.
Old Sep 20, 2007 | 11:15 AM
crazyguy's Avatar
Default Re: (Hondaciv95VX)
on your 95 civic..main relay is located at driver side kick panel..i think it is your main relay problem
Old Sep 20, 2007 | 08:23 PM
Default Re: (crazyguy)
Alkright thats more help then ive gotten newhere thanks bro!!
ewok1
12
Aug 2, 2009 07:36 PM
prf0188
Mar 3, 2008 08:14 AM
boosted_lude
Jun 14, 2007 01:32 PM
stoned_sol
Aug 4, 2005 03:15 AM
