Vtec not working(b16)...plz look..
Old Sep 19, 2007 | 05:05 PM
91EF_Si's Avatar
Default Vtec not working(b16)...plz look..
I have a 91 hatch with a b16a. obd1 motor and ecu. I had it running with a obd1 pr3 ecu and it hit vtec fine...then it just stopped. Tried out the ecu on my friends b16 and it didn't work. So I put in a new vtec solenoid and chipped vtec ecu, and still doesn't work. ONLY way it works is, if I wire a button to a 12v source and the solenoid.
Any ideas on why it's not working?
Old Sep 19, 2007 | 05:33 PM
denraweb's Avatar
Default Re: Vtec not working(b16)...plz look.. (91EF_Si)
Check the continuity from where the harness plugs into the ecu to the vtec solenoid and see if the wire is still good. Ultimately you could have a bad IAT sensor (White sensor on the intake manifold), which for me, made my vtec stop kicking in on my civic (obd1 also)
Old Sep 19, 2007 | 06:22 PM
91EF_Si's Avatar
Default Re: Vtec not working(b16)...plz look.. (denraweb)
Yea my jumper harness looks hurt, but still making contact. I'm gonna try out a different IAT sensor and see what happens.
Old Sep 19, 2007 | 06:26 PM
91EF_Si's Avatar
Also, I have no CEL codes. Shouldn't that bring up a code?
Old Sep 19, 2007 | 07:11 PM
prettylew's Avatar
do u have oil in the car? sometimes low oil wont make vtec kick in. also ive heard of the MAP, and VSS sensor wires making vtec not work, also look at the oil pressure wire and make sure thats all good
Old Sep 20, 2007 | 05:29 AM
91EF_Si's Avatar
Default Re: (prettylew)
all wires and oil is good...bump for more help
Old Sep 20, 2007 | 08:17 AM
JDM_b20's Avatar
Default Re: (91EF_Si)
Knock sennsor mabe
Old Sep 20, 2007 | 08:24 AM
91EF_Si's Avatar
Default Re: (JDM_b20)
Knock sensor is eliminated, with this ecu.
Old Sep 21, 2007 | 05:14 PM
Rexxer's Avatar
well like you said if you put your ecu in your friends and his wouldnt engage, its your ecu. get a new one =P cause if works from a switch everything mechanical is working.
Old Sep 21, 2007 | 05:52 PM
spastik's Avatar
have you tried a vtec light yet?
oh.. check this thread too
https://honda-tech.com/zerothread?id=830163
HYBRID_H@TCH
26
Apr 14, 2007 01:17 PM
vegaskurt
Jun 20, 2006 09:31 PM
686_ef
12
Feb 13, 2006 08:31 PM
Rod.
Mar 16, 2004 11:07 PM
redhnda
Jan 27, 2003 09:35 PM
