Mini me d16y7 block y8 head ECU smog question.
Old Sep 19, 2007 | 10:59 AM
Ser1N's Avatar
Default Mini me d16y7 block y8 head ECU smog question.
Ok so i need to pass smog soon here and i been using a p28 ECU with harness. Now will the car run ok with a P2E ECU run ok just to go to the smog station and pass? I hear the injector sizes are different in the Y7 and Y8 but would that make a world of difference?
Old Sep 19, 2007 | 12:13 PM
Ser1N's Avatar
Default Re: Mini me d16y7 block y8 head ECU smog question. (Ser1N)
Anyone? a DX ECU would be set for lower injectors (if DX injectors are in fact lower) with EX injectors. would the car run like crap?
Old Sep 19, 2007 | 02:28 PM
Ser1N's Avatar
Old Sep 19, 2007 | 03:09 PM
Ghetto Civic HX's Avatar
I love to drive
Unless the smog tech is not paying any attention, you'll probably fail because of the mini me.
My car is stock and every time I've gone in for a smog, the techs check everything.
Old Sep 19, 2007 | 03:18 PM
Ser1N's Avatar
Default Re: Mini me d16y7 block y8 head ECU smog question. (Ghetto Civic HX)
being in san diego ill proly just find some ghetto *** place, but i just dont want to mess up the engine by using a 240CC ECu on 180CC injectors. i dont know if will run at all hahah
Old Sep 20, 2007 | 10:36 AM
Ser1N's Avatar
anyone?
Old Sep 20, 2007 | 10:49 AM
96 EX's Avatar
If you try and run the DX ecu with the y8(vtec head) it will run like **** and im pretty sure the tech will notice since its pretty obvious. You will need the ex ecu for vtec to run correctly and you will need to swap the injectors out for the 240cc being that those are the correct injectors for the vtec head.
Old Sep 20, 2007 | 10:59 AM
Ser1N's Avatar
Default Re: Mini me d16y7 block y8 head ECU smog question. (96 EX)
well i have the 240CC in there now i just didnt want to go through all the trouble of hooking up knock sensor and stuff but it looks like i am going to have too anyway. thanks for the thoughts
titi_vtec
Jan 28, 2013 11:55 AM
gurlugotmilk
Feb 6, 2009 06:29 PM
d1nki
Dec 6, 2007 12:24 PM
Sleepy86o
14
Oct 4, 2007 03:25 PM
gsr9ek6
Nov 8, 2005 04:36 PM
