code 24?
Old Sep 19, 2007 | 10:14 AM
blwn95civic's Avatar
Default code 24?
well i knew my car was throwing code 41 due to my o2 sensor takin a crap on me awhile back. But i just checked it again and im also gettin code 24 followed by 41. What does code 24 stand for?
Old Sep 19, 2007 | 10:17 AM
crazyguy's Avatar
Default Re: code 24? (trav95civic)
41 is oxygen soensor.i used to have that problem too. just simply replace it will make CEL go away.but code 24 does not exist.
Old Sep 19, 2007 | 10:19 AM
Default Re: code 24? (crazyguy)
well when i turn my key the check engine light flashes real quick then turns off, from there it does two 1 second flashes, then four half second flashes followed by the code 41.... ill go check again but im pretty sure thats wat its reading, i thought this was weird also b/c i couldnt find a code 24
Old Sep 19, 2007 | 10:23 AM
*edit*
after watching it again and looking for more codes i realized its throwing code 1, 10, 14, then 41
the code 10 and 14 were confusing me thats where i got the 24... my bad haha
Old Sep 19, 2007 | 10:32 AM
mckrank313's Avatar
i'm gonna be a dick for doing this but since you are asking what the codes are... did you check the top of this forum?
https://honda-tech.com/zerothread/1901557
that my is all the codes
1=o2 sensor 1
10=iat
14=iac
41=Primary oxygen sensor heater
1and 41 go together...
Old Sep 19, 2007 | 10:57 AM
Default Re: code 24? (mckrank313)
i know the codes, hence i knew wat code 41 was the only code i asked for was code 24 because i was reading the flash wrong like i said earlier, but thank you for trying to be a dick
Old Sep 19, 2007 | 11:30 AM
mckrank313's Avatar
oh ok my fault then
Mr.Death
Apr 30, 2010 05:51 PM
EKtypeRhaTcH
Jan 13, 2005 04:53 AM
mprelude
Jan 10, 2005 11:52 AM
turbotime
Jul 20, 2003 08:11 AM
