del sol linkage question!! please help!!!
i have a question i have a del sol shell and iam dropping in a sohc in it! will the civic linkage fit in this ok? i know dohc linkage is different but what about sohc....;.thanks
Re: del sol linkage question!! please help!!! (skUnK2jdm)
If its a D motor then you need D linkage.
If a B motor then you need B linkage for a del sol only.
Not sure if the del sol D linkage is specific but I would imagine as the Del sol with a B using teggy linkage the linkage is about 1.25 inches too short.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skUnK2jdm »</TD></TR><TR><TD CLASS="quote">do u think i need the del sol d linkage?</TD></TR></TABLE>
yes u will need d series shift linkage.but check with your local honda dealer if civic d series shift linkage will fit on your del sol cause i think del sol has shorter shifter linkage than civic in b series ...not sure about d series..
"crazyguy" is correct,.. you need a Del Sol "D" series shift linkage. I swaped my "D" for a "B" and my close friend put the "D" series motor on his EG and the shift linkage wouldnt work due to the bends on the Del Sol linkage is different.
SOLvtec
10-27-2006 09:30 AM
