code 24?
well i knew my car was throwing code 41 due to my o2 sensor takin a crap on me awhile back. But i just checked it again and im also gettin code 24 followed by 41. What does code 24 stand for?
Re: code 24? (trav95civic)
41 is oxygen soensor.i used to have that problem too. just simply replace it will make CEL go away.but code 24 does not exist.
Re: code 24? (crazyguy)
well when i turn my key the check engine light flashes real quick then turns off, from there it does two 1 second flashes, then four half second flashes followed by the code 41.... ill go check again but im pretty sure thats wat its reading, i thought this was weird also b/c i couldnt find a code 24
*edit*
after watching it again and looking for more codes i realized its throwing code 1, 10, 14, then 41 the code 10 and 14 were confusing me thats where i got the 24... my bad haha https://honda-tech.com/forums/images...es/emsmile.gif |
i'm gonna be a dick for doing this but since you are asking what the codes are... did you check the top of this forum?
https://honda-tech.com/zerothread/1901557 that my is all the codes 1=o2 sensor 1 10=iat 14=iac 41=Primary oxygen sensor heater 1and 41 go together... |
Re: code 24? (mckrank313)
i know the codes, hence i knew wat code 41 was https://honda-tech.com/forums/images/smilies/emwink.gif the only code i asked for was code 24 because i was reading the flash wrong like i said earlier, but thank you for trying to be a dick https://honda-tech.com/forums/images...s/emsmilep.gif
oh ok my fault then
