removing ignition tumbler?
Old Sep 19, 2007 | 05:51 AM
turbo-crx's Avatar
Default removing ignition tumbler?
I Have A 90 Crx And Im Trying To Install A New Ignition Tumbler But I Cant Get The Old Tumbler Out. I Pushed The Pin Down And The Key In Position 1 But It Wont Come Out. Any Ideas How To Get It Out?
Old Sep 19, 2007 | 08:15 AM
dem0nk1d's Avatar
i think if i can rember correctly you have to have the key in and set to I. then it should slide out with a little work.
Old Sep 19, 2007 | 08:27 AM
65stang90crx's Avatar
Default Re: (dem0nk1d)
Please no one reply to this post. As it can aid in theft of our precious cars.
Old Sep 19, 2007 | 08:31 AM
turbo-crx's Avatar
the key is in the ignition and in position 1 but it wont slide out, i wingled it pulled it and nothing. how far does the pin have to go down? I have the new tumbler in front of me and the pin doesnt need to be pushed down very far
Old Sep 19, 2007 | 08:33 AM
turbo-crx's Avatar
Default Re: (turbo-crx)
please reply to this post, my car wont stay started with out a new ignition lock
Old Sep 19, 2007 | 09:38 AM
boosted91crx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 65stang90crx &raquo;</TD></TR><TR><TD CLASS="quote">Please no one reply to this post. As it can aid in theft of our precious cars.</TD></TR></TABLE>
No it wont, for this to work you NEED the key and you need it in position 1, if a theif has the key he wont bother pulling out the tumbler, that aside it should pull right out when its in the proper location, unless its bent or has been forced. however if your ignition has a electrical problem, changing the tumbler alone wont fix it, you need to change the entire thing.
George Knighton's Avatar
H-T Order of Merit
People might be afraid to reply because they don't have a complete picture of why you are removing the ignition switch. If you don't mind giving people a little more information, that might help.
You might also want to pop into the Audio/Security/Electronics forum, since they seem to have a wealth of knowledge about everything electric.
Old Sep 19, 2007 | 11:59 AM
turbo-crx's Avatar
Default Re: (George Knighton)
the problem im have is that when i start the car and let it return to the on position it shuts off. when the key is in the ignition it doesnt stay still while its in position. you can turn it from position 1 and 2 freely. the only way to drive it is to start the car and not let it fall to the on position, so i have to hold it still so the car stays on. could i remove the ignition switch and push from the back of the tumbler to try and get it out? any help is appreciated im tired of holding the key in place while driving its pretty tricky
Old Sep 19, 2007 | 12:07 PM
GreenBean's Avatar
You need to replace the electrical part of the ignition switch:
It's the "rotary switch" that is attached to the buttom of the ignition switch itself. We do them all the time in our shop...
Most dealers wil know it if you call it that "electrical part of the ignition switch" God Speed on fixing it...
<FONT COLOR="red">I made up the name rotary switch years back, sorry if it throws anybody off...</FONT>
Old Sep 19, 2007 | 12:11 PM
GreenBean's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbo-crx &raquo;</TD></TR><TR><TD CLASS="quote">the problem im have is that when i start the car and let it return to the on position it shuts off. when the key is in the ignition it doesnt stay still while its in position. you can turn it from position 1 and 2 freely. the only way to drive it is to start the car and not let it fall to the on position, so i have to hold it still so the car stays on. could i remove the ignition switch and push from the back of the tumbler to try and get it out? any help is appreciated im tired of holding the key in place while driving its pretty tricky</TD></TR></TABLE>
ALso, they are not that costly, some on-line places sell them for under 16 bucks.
Old Sep 19, 2007 | 12:59 PM
turbo-crx's Avatar
Default Re: (GreenBean)
WELL HONDA WANTS 75 DOLLARS FOR IT. IS IT THE PART WITH ALL THE WIRES OR IS IT THE PART THAT IS BOWL SHAPED THAT THE IGNITION SWITCH GOES IN?
Old Sep 19, 2007 | 01:10 PM
dem0nk1d's Avatar
some times their is a star bit that needs to be taken out. size is around 1/16 of inch.
Old Sep 20, 2007 | 04:32 AM
GreenBean's Avatar
What model CRX do you have, HX, DX, or SI...I need to be sure...
Old Sep 20, 2007 | 04:37 AM
GreenBean's Avatar
My bad...
PN 35130-SH5-505 retail should be around 62-63 dollars...
Part number 7 is what your looking for...
http://www.bernardiparts.com/S...3.GIF
Old Sep 20, 2007 | 08:03 AM
turbo-crx's Avatar
thanks man. i went to honda today and bought it. 65 dollars with tax and it fixed my problem. thanks for your help bro
Old Sep 20, 2007 | 09:53 AM
GreenBean's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbo-crx &raquo;</TD></TR><TR><TD CLASS="quote">thanks man. i went to honda today and bought it. 65 dollars with tax and it fixed my problem. thanks for your help bro</TD></TR></TABLE>
Anytime, that's why were here, knowledge is power and that helps people save money $$$$$....Which means more money to go faster.
Old Sep 20, 2007 | 01:50 PM
turbo-crx's Avatar
hell ya im going to the track sat hoping to trap 125mph
dustinrathke24
Sep 14, 2018 01:00 PM
_Spugen_
14
Jan 17, 2005 01:49 PM
137
Sep 30, 2004 03:48 AM
liljohnson
Aug 12, 2004 11:48 PM
wizzards581
12
Dec 11, 2003 06:25 PM
