Block Gaurd or Sleeve?
Old Sep 18, 2007 | 07:22 PM
BmfoHPWW's Avatar
Default Block Gaurd or Sleeve?
I have a 96' gsr that i am hopefully going to turbo, i am rebuilding it with all low comp. pistons and forged rods, i want to run about 13 or 14 psi but am not sure if the stock sleeve will hold up or not, cuz that would be some money saved?
Old Sep 18, 2007 | 07:43 PM
BmfoHPWW's Avatar
oh yeah and its going to be running on a garrett t3/t4 with a .63 a/r turbine, and a custom made mini ram horn
Old Sep 18, 2007 | 07:45 PM
blwn95civic's Avatar
Default Re: Block Gaurd or Sleeve? (BmfoHPWW)
even 1lb of boost requires sleeving
not..... search for what you want to know... probably under "stock block". You have a lot of reading and research to do
Old Sep 18, 2007 | 07:52 PM
Hotori Hanso's Avatar
Default Re: Block Gaurd or Sleeve? (trav95civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trav95civic &raquo;</TD></TR><TR><TD CLASS="quote">even 1lb of boost requires sleeving</TD></TR></TABLE>
uuuh ok...
Old Sep 18, 2007 | 08:04 PM
Default Re: Block Gaurd or Sleeve? (Hotori Hanso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hotori Hanso &raquo;</TD></TR><TR><TD CLASS="quote">
uuuh ok...</TD></TR></TABLE>
its sarcasm buddy
Old Sep 18, 2007 | 08:10 PM
morgan@synapse motorsport's Avatar
no block gaurd stock sleeves 81.5mm bore
Old Sep 18, 2007 | 11:16 PM
lambertincorp's Avatar
Default Re: (mike@synapse motorsport)
what are your power goals?
Old Sep 19, 2007 | 05:17 AM
Schister66's Avatar
Man U FTW
dont measure your goals in terms of PSI because its an irrelevant measurement. Also, you probably dont need aftermarket sleeves or want a block guard. There are several cars in the upper 400s safely on stock sleeves and i know there are more beyond that even....
Old Sep 19, 2007 | 07:03 PM
BmfoHPWW's Avatar
yeah after i did some research i dont need a sleeve but most people say to put a block gaurd in but now im not sure what to do, what is th downside to having it?
Old Sep 19, 2007 | 07:19 PM
project dc2's Avatar
Default Re: (BmfoHPWW)
downside to having it without machining is distorting your cylinder walls, thus causing irregular wear. also, blockage of coolant passageways causing overheating.
14 psi of boost. stock sleeves with forged bottom end and a great tune would do wonders
Old Sep 19, 2007 | 07:26 PM
BmfoHPWW's Avatar
Thanks alot i think that the stock sleeves, with the forged bottom end seems to be the way to go!
Old Sep 19, 2007 | 07:35 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BmfoHPWW &raquo;</TD></TR><TR><TD CLASS="quote">Thanks alot i think that the stock sleeves, with the forged bottom end seems to be the way to go!</TD></TR></TABLE>
yep K.I.S.S. KEEP IT SIMPLE STUPID !
Old Sep 20, 2007 | 04:11 AM
CRX11Z's Avatar
i run a stock b16a block, no sleeves at 34psi boost, car runs 9.93@147mph, havnt had a problem yet! done over 150 passes on this engine and havnt even had the rocker cover of it!....
Old Sep 22, 2007 | 04:57 AM
reaction360's Avatar
Default Re: (CRX11Z)
stock sleeves, 81.5mm bored, 10:1 compression pistons ftw
Old Sep 22, 2007 | 09:42 AM
reactiondc2's Avatar
Default Re: (reaction360)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by reaction360 &raquo;</TD></TR><TR><TD CLASS="quote">stock sleeves, 81.5mm bored, 10:1 compression pistons ftw</TD></TR></TABLE>hey you just listed my motor from last year buddy...i ran it at 22lbs of boost from an sc61 then i sold it after the season...still running strong for the new owner
DVPTeG
May 22, 2007 08:34 PM
japspecb7
Apr 17, 2007 04:18 PM
LilCivic04
Feb 1, 2005 06:17 PM
imthedude
Oct 16, 2003 09:44 AM
projectTeG
Oct 14, 2003 01:33 PM
