Any easy way to replace the rear mount without lifting the engine?
Old Sep 18, 2007 | 06:17 PM
crazyguy's Avatar
Default Any easy way to replace the rear mount without lifting the engine?
i think my rear mount might have gone bad.it is a b16a2 engine. anyone knows an easy to replace that mount without have to lift the whole engine? thanks.
Old Sep 18, 2007 | 06:41 PM
coupecrazy1's Avatar
Default Re: Any easy way to replace the rear mount without lifting the engine? (crazyguy)
put a floor jack with a peice of wood under the oil pan and jack it up alittle and remove the mount ull be fine
Old Sep 18, 2007 | 06:56 PM
drtysohc's Avatar
^^^^+1
it'll be a bitch though.
Old Sep 18, 2007 | 06:57 PM
highroller54's Avatar
Default Re: (drtysohc)
pull the t bracket of the engine/trans first.
Old Sep 18, 2007 | 07:17 PM
hondamark35's Avatar
what makes you think that it is bad?
Old Sep 19, 2007 | 12:27 PM
crazyguy's Avatar
Default Re: Any easy way to replace the rear mount without lifting the engine? (hondamark35)
thansk guys..acutally i am thinking of replacing them with hasports mounts
Old Sep 19, 2007 | 01:01 PM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazyguy &raquo;</TD></TR><TR><TD CLASS="quote">thansk guys..acutally i am thinking of replacing them with hasports mounts</TD></TR></TABLE>
yeah it is a bithc to replace, a very tight area. i suggest you take your time and pick up some swivel socket links. it'll make the job alittle easier.
Old Sep 19, 2007 | 01:04 PM
Archidictus's Avatar
Unceasing Measure
Default Re: Any easy way to replace the rear mount without lifting the engine? (philosofy1)
Yeah, it's an annoyance, but once you've done it you'll be able to do it again in about 30 minutes Expect 2 hours the first go-round.
Old Sep 20, 2007 | 05:39 AM
crazyguy's Avatar
Default Re: Any easy way to replace the rear mount without lifting the engine? (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, it's an annoyance, but once you've done it you'll be able to do it again in about 30 minutes Expect 2 hours the first go-round.</TD></TR></TABLE>
yeah i think i know how to do it cause i swapped b16a into my eg myself.i just dont want to deal with the engine hoist again to lift the entire engine just to replace the rear mount..
Old Sep 20, 2007 | 06:58 AM
Murk 'EM's Avatar
take the intake manifold off..... youll have a straight shot.... even tho i had no problem when puttin a b16 in my eg with it all togeather
Old Nov 27, 2007 | 05:34 PM
nigelnuggets's Avatar
Default Re: Any easy way to replace the rear mount without lifting the engine? (Murk 'EM)
I tried looking at the best way to do it, would you guys hit it from the underside or from the top?
I myself have to replace a rear engine mount since my driver side was broken, i decided to buy a whole set of Innovative Steel mounts. The driver side and passenger side mounts were a breeze, and now im stumped at the approach for the rear engine mount, because i had JUST dropped in my D15B, and the mount broke soon after, and i really dont want to pull her out again.
Has anyone done it before? (DIY maybe? :D )
Whatislove
Honda Civic (2001 - 2005)
Jul 21, 2011 01:44 PM
kingofbattle909
Feb 14, 2011 06:34 AM
PatrickGSR94
Oct 16, 2008 02:04 PM
Civic168
Suspension & Brakes
Feb 28, 2006 09:21 PM
b16ek4
Jun 25, 2005 10:35 AM
