knock/clunk when i make quick hard right turns...
Old Sep 18, 2007 | 09:02 AM
SoCal EJ1's Avatar
Default knock/clunk when i make quick hard right turns...
it sounds and feels like its coming from the front driver's side suspension but it could just be the front in general. would this be something in the steering rack or sway bar end links or what?
Old Sep 18, 2007 | 09:29 AM
sql_civic's Avatar
Default Check it out
Jack up your car and look around underneath.
Maybe your CV joint boot is ripped.
Old Sep 18, 2007 | 09:33 AM
pdiggitydogg's Avatar
if its heavy, its more than likely a ball joint
dont let this go for long...
Old Sep 19, 2007 | 05:31 PM
SoCal EJ1's Avatar
Default Re: Check it out (sql_civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sql_civic &raquo;</TD></TR><TR><TD CLASS="quote">Jack up your car and look around underneath.
Maybe your CV joint boot is ripped.</TD></TR></TABLE>
not CVs, i've checked them and both have torn in the past and since been replaced.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">if its heavy, its more than likely a ball joint
dont let this go for long...</TD></TR></TABLE>
i'm probably blanking out as i write this, but where am i looking / what am i looking for to check?
Old Sep 19, 2007 | 05:42 PM
You have ball joints upper and lower, they hold the knuckle to control arms.
The lower wears out before upper, typically. If you take off your wheel and look at the very bottom of the knuckle, you'll see a stud and nut - thats the bottom of the ball joint
Old Sep 19, 2007 | 05:56 PM
SoCal EJ1's Avatar
Default Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">You have ball joints upper and lower, they hold the knuckle to control arms.
The lower wears out before upper, typically. If you take off your wheel and look at the very bottom of the knuckle, you'll see a stud and nut - thats the bottom of the ball joint</TD></TR></TABLE>
Ok, am i looking for the same kinda thing that i have on the UCAs cuz I'm familiar with those.
Old Sep 19, 2007 | 06:01 PM
basically...
more pics:
https://honda-tech.com/zerothread?id=887859
Old Sep 19, 2007 | 06:09 PM
SoCal EJ1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">basically...
[img]https://img.photobucket.com/albums/v38/Luserkid/fc495f53.jpg[/img
more pics:
https://honda-tech.com/zerothread?id=887859</TD></TR></TABLE>
cool, thanks. and assuming its torn/worn/etc is it a simple fix or is this gonna be a mechanic's job?
Old Sep 19, 2007 | 06:21 PM
95dxsir2's Avatar
Default Re: (SoCal EJ1)
do you have access to ball joint removal/install tools? so do u really want to diagnose this or just have a shop do it?
Old Sep 19, 2007 | 06:31 PM
SoCal EJ1's Avatar
Default Re: (95dxsir2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95dxsir2 &raquo;</TD></TR><TR><TD CLASS="quote">do you have access to ball joint removal/install tools? so do u really want to diagnose this or just have a shop do it?</TD></TR></TABLE>
Well i want to diagnose the problem before I take it to the shop. They don't drive my car like i do so they're not gonna hear the noise. If the ball joint's the issue, then yes, the shop will take care of it because I do not have access to the tools. I just don't want the shop to give me a list of things I need to fix if it's just one things, you know how it is.
horror
Jul 29, 2014 01:14 PM
nonvteclude
Jul 13, 2007 06:18 AM
nomoreavril
17
Dec 14, 2006 09:25 PM
siguy4
May 13, 2006 05:23 PM
Ideal
Apr 5, 2005 11:40 PM
