VTEC problem (built turbo H22A4)
Old Sep 18, 2007 | 08:19 AM
ImPuLsIvE's Avatar
Default VTEC problem (built turbo H22A4)
I'm having a problem with VTEC. Ever since I swapped my built H22A4, CEL 21 (Vtec solenoid) has always been there.
At first I thought it was the wiring, but it checked out perfectly fine (continuity when plugged in the ECU, no continuity when disconnected). So, following the flow chart in the shop manual, I changed the VTEC solenoid all together. The problem still persists.
I checked the continuity on the ECU, to see if maybe VTEC wasn't installed right (the ECU is a custom chipped P06). But the pins check out fine.
Should I bring the ECU back to the guy who chipped/tuned it and tell him there's something wrong with it? Or is there another way to trouble shoot the VTEC solenoid itself?
What should I do? I'm really bunked on this.
Any help would be greatly appreciated.
Old Sep 18, 2007 | 01:02 PM
ImPuLsIvE's Avatar
Anyone??
Old Sep 18, 2007 | 05:48 PM
QUIETP_11's Avatar
Default Re: (ImPuLsIvE)
I don't know what the inside of that particular ECU looks like, but if there is a way to check the continuity between the external connection (which appears to be ok from your previous tests) and the trace on the printed-circuit-board. Also survey the whole ECU to make sure there aren't any broken/disrupted traces.
Old Sep 18, 2007 | 08:16 PM
marshun's Avatar
Default Re: (QUIETP_11)
talk to the guy who chipped it
CivicSi95
Honda Civic (2006 - 2015)
Nov 22, 2008 11:20 AM
94ludeh22
Nov 16, 2005 07:14 AM
spoon23_JDizM AkA SpOoN20
Oct 6, 2005 05:01 PM
tuckin15s_8315
Sep 28, 2005 09:35 PM
