vtec not working? on ls-vtec
Old Oct 5, 2005 | 10:42 PM
spoon23_JDizM AkA SpOoN20's Avatar
Default vtec not working? on ls-vtec
but codes are not coming up...????
Old Oct 5, 2005 | 10:47 PM
Kendall's Avatar
Details on the setup please? Also, what ECU are you using?
Old Oct 5, 2005 | 10:50 PM
Default Re: (Kendall)
p28 ecu,built gsr head with type r cams and full ferrea valvetrain
Old Oct 5, 2005 | 11:02 PM
Kendall's Avatar
First determine whether it's electrical or mechanical. Test the ECU in another car to see if it activates VTEC properly, or try another ECU in your car. Unplug something vital (like the TPS) to see if it throws the car in limp mode and throws a code with the present ECU. Also check the voltage going to the VTEC solenoid after the set VTEC point. If all of that checks out, upload the BIN out of the ECU and check to make sure the VTEC crossover is where it's supposed to be.
If you determine that it's not electrical, then start looking for details like a dirty VTEC solenoid, or accidentally not installing that little o-ring under the #3 cam cap.
Old Oct 6, 2005 | 05:01 AM
Too_Smooth's Avatar
Default Re: (spoon20)
Since you say you have a built head I'm going to assume it was disassembled at some point. Check and make sure that all the pins are in the rocker arms if the problem isn't electrical. Happen to me....and took me a minute to figure out the problem.
Good luck
Old Oct 6, 2005 | 05:01 PM
Default Re: (Too_Smooth)
will check...any more info would be glady aprreciated
Joshua_Missey
Honda Civic (2001 - 2005)
Jun 28, 2018 12:35 PM
heflin94eg
Engine Management and Tuning
Dec 4, 2012 05:19 PM
error2k
Mar 3, 2010 12:47 PM
dougk1401
Dec 7, 2009 08:55 AM
ImPuLsIvE
Sep 18, 2007 08:16 PM
