Vtec problem HELPPP!!! weird!!
i have a 98 gsr 9 (stock) the car its actin weird, vtec stops workin once in a while. check engine will go on and vtec stops workin, so i go and unplug the battery and plug it back on and still doesnt work but no check engine, while drivin sometimes vtec works, and when the vtec doesnt work the motor sounds different, intake noise gets louder, so far nobody could fix the problem so i was wonderin if u guys know wat the problem might be
You wanna know what I would do? I would take it to HONDA. haha. I can change change a spare tire, and oil.. I wish I could work on my car like all you lucky bastards...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bowser_cd5 »</TD></TR><TR><TD CLASS="quote">did you check your vtec fluid?</TD></TR></TABLE>
is Vtec fluid right beside the pixie dust and magic lattern on the gold plated firewall? hahaha
Seriously tho, there is no such thing as Vtec Fluid, sadly some people just suck at life....I had this same issue with my '01 GSR, my CEL comes on if I stay in Vtec for a long period of time....usually 5 min of just cruising around 4600rpm....i found out my motor was loosing oil pressure (crucial for Vtec engagement)
check your oil, 95% of Vtec problems are oil issues(this is what my Honda dealer told me)
also if you want to check everything...take off the Vtec solenoid and clean the filter, sometimes a little dust can get in there and mess things up....this happened to my friends '00 GSR
The ECM/PCM has to have these prerequisites before it will allow the VTEC solenoid to activate:
Vehicle Speed
RPM
Engine Coolant Temp.
Oil Pressure
Throttle Position
Also, if you have a CEL it won't work either. If you can make sure that all of these sensor are reporting to the ECM/PCM correctly, then you can start looking for some kind of mechanical problem/interference (dirt on the spool valve screen, blockage in the oil passages etc...) I am not sure what code 8 is on an OBDII Integra, but I would get the code checked by Acura or someone that can tell you what code it is. Should be like a Pxxx. Hope this helps.
Modified by Teufeldog at 1:56 AM 9/19/2007
Vehicle Speed
RPM
Oil Pressure
Throttle Position
