Tempature problems on Si B16a
Old Sep 17, 2007 | 03:33 PM
---'s Avatar
Default Tempature problems on Si B16a
I'm having problems with the tempature reading on my car. I not sure if it's the themostat though, since I don't know much about mechanical issues yet. The tempature has random rushes that make it go about 3/4's of the way then drops back down to normal. What would be the sympthoms? Or what else could be the problem if its not the thermostat?
Old Sep 17, 2007 | 05:17 PM
egsleepercivic's Avatar
Default Re: Tempature problems on Si B16a (Rays_07)
try bleeding the cooling system there should be a bleeder valve by the thermostat
Old Sep 18, 2007 | 05:21 PM
Quitripin's Avatar
Default Re: Tempature problems on Si B16a (egsleepercivic)
look at the thermostat under the throttle body and check if the ground is bolted down.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egsleepercivic &raquo;</TD></TR><TR><TD CLASS="quote">try bleeding the cooling system there should be a bleeder valve by the thermostat</TD></TR></TABLE>
check if your coolant is topped off, turn on the heater
Old Sep 19, 2007 | 06:27 PM
---'s Avatar
oh alright ill go ahead and check that out, hope that gets it done... good looking out egsleepercivic & quitripin...
B16AJDM
16
May 22, 2009 12:00 PM
nonhondaman
Apr 17, 2007 07:26 PM
ge_itr
Nov 30, 2006 04:10 PM
hatch_
Jan 25, 2006 07:10 PM
B1B-EK
Nov 17, 2005 03:47 PM
