18G vs T3/To4E on B18c1
Old Sep 17, 2007 | 10:48 AM
motormike40's Avatar
Default 18G vs T3/To4E on B18c1
Which turbo Dsm 18G or T3/t04e (57 trim, .63 ar hotside .50 coldside) which turbo will spool up quicker and put down 300 whp, and not run out of breath at 8,000 rpm on a b18c1? Thanks.
Old Sep 17, 2007 | 11:13 AM
SOHC_MShue's Avatar
Default Re: 18G vs T3/To4E on B18c1 (motormike40)
Go with the 57trim. The 18g will run out of breath and you wont make the power you want. Plus the 57trim wont have bad spool up time either.
boostedcivicsir's Avatar
Mr. Badwrench
not the 18g.
the t04e worked well on a friends setup. but that was a high comp b16.
Old Sep 17, 2007 | 11:19 AM
2k_teg_gsr_t's Avatar
go with a 60 trim t3/t4
Old Sep 17, 2007 | 11:22 AM
EKlscoupe_98's Avatar
Default Re: 18G vs T3/To4E on B18c1 (2k_teg_gsr_t)
t3/to43 57 is nice for a b18c1 i think makes good power should be full spool around 5 i think
Old Sep 17, 2007 | 11:57 AM
quicksilver1689's Avatar
i ♥ snails
nothing wrong with the 18g, the 57 trim will allow you to reach full potential of your setup
Old Sep 17, 2007 | 12:06 PM
Schister66's Avatar
Man U FTW
57 trim would be a great turbo for your stock GSR...if you want a little faster spool w/ the same peak power, you could opt for the GT3255 series. I run a GT3255b on my stock GSR and make 315/216 at 10psi w/ full boost on the street at around 3900rpm. If you want more info, you can PM me and i'll get you the details along w/ my dyno graph
Old Sep 17, 2007 | 12:50 PM
BoostR41's Avatar
Default Re: (Schister66)
the 18G will do 300whp I did 309whp on the 18g on my old set up, but the 57 trim is a better option
Old Sep 17, 2007 | 01:44 PM
Cool, thanks alot for the inputs.
Old Sep 17, 2007 | 02:00 PM
gsr x civic's Avatar
Default Re: (BoostR41)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostR41 &raquo;</TD></TR><TR><TD CLASS="quote">the 18G will do 300whp I did 309whp on the 18g on my old set up, but the 57 trim is a better option</TD></TR></TABLE>
what psi were you at? and what other mods did you have done aside from the stock greddy kit?
the 18g has a great spool time, and spools up faster than the 57 trim. but like everyone else said, the 57 trim IS a bigger turbo and will make almost full, if not all, potential on your stock gsr.
Old Sep 19, 2007 | 09:12 PM
BoostR41's Avatar
Default Re: (gsr x civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsr x civic &raquo;</TD></TR><TR><TD CLASS="quote">what psi were you at? and what other mods did you have done aside from the stock greddy kit?
the 18g has a great spool time, and spools up faster than the 57 trim. but like everyone else said, the 57 trim IS a bigger turbo and will make almost full, if not all, potential on your stock gsr. </TD></TR></TABLE>
17psi. stock cast elbow flared to 2.5" dp to 3" exhaust, 880cc injectors, hondata build bottom end on stock ITR head
Old Sep 19, 2007 | 09:17 PM
what duty cycle was your injectors at?
i have 450's and i wanna make 300 also.
Old Sep 20, 2007 | 05:49 AM
401tuner's Avatar
you could even go with a .50 trim if you wanted. better spool up time and still produces good numbers.
Old Sep 20, 2007 | 07:42 AM
hey will the 450's be enough for the 300whp i want to put out?
Old Sep 20, 2007 | 11:00 AM
Schister66's Avatar
Man U FTW
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsr x civic &raquo;</TD></TR><TR><TD CLASS="quote">hey will the 450's be enough for the 300whp i want to put out? </TD></TR></TABLE>
get 550s at least
Old Sep 20, 2007 | 04:48 PM
urbansi's Avatar
how many of you actually have expierence with both, cuz i do.
I loved my 18g, but i wanted to make 400whp and with a built motor the 18G was a waste.
This was on my b16, 11psi with the gate maxed and a 3in DP with the internal wastegate. Thing pulled all the way to redline and saw full boost before 3,500
with an external gate and more tuning it would have made well over 300, not to mention the tq it would have made
Old Sep 20, 2007 | 06:04 PM
ghostskinner's Avatar
Default Re: (urbansi)
what rpm would the 57 trim spool at on a b16 63 ar exhaust housing of course
Old Sep 22, 2007 | 08:00 AM
401tuner's Avatar
Default Re: (ghostskinner)
interested also, but more interested in the .50 trim
the.hamburglar
Oct 11, 2006 08:01 PM
typesguy
Mar 24, 2005 09:31 AM
SiRkid
Oct 9, 2002 11:19 AM
