fuel injectors (searched)
saturated- low independent
peak an hold- high independent
is that right? or is it the other way around?
also i rememeber seeing a chart of other stock injecotrs an the cc for each. anyone else seen it?
saturated - (high impedence) requires no resistor box: 92+ injectors
peak and hold - (low impedence) requires resistor box: >92 injectors, common 1000cc+ sized injectors and dsm injectors
Heres how I remember it: peak and hold, think of hold like resistance, resistance "holds". Impedence is resistance so a low impedence injector has low resistance, which would require a resistor box. You can run a resistor box with saturated injectors (resistance would be high, >20ohms) but they will still work.
perfect. thanks mang. exactly what i wanted to know.
do u know thread im talking about. tells you almost all the trubo cars injector size. seupr,rx7 ect.
b16bri
Sep 5, 2010 02:53 PM
skeetahendo
Mar 15, 2008 03:44 AM
