gt4088 vs. gt4088r
gt4088 vs. gt4088r
Well the gt4088r is twice as much as the gt4088. Is there any diff. between the two turbos besides one is ball bearing and one is not? Is it worth going ball bearing for the extra 900?
Re: gt4088 vs. gt4088r (boost fed ls)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boost fed ls »</TD></TR><TR><TD CLASS="quote">Well the gt4088r is twice as much as the gt4088. Is there any diff. between the two turbos besides one is ball bearing and one is not? Is it worth going ball bearing for the extra 900?</TD></TR></TABLE>
Basically completely different turbos actually
A GT4088R compressor specs are
63.5mm Inducer
88mm Exducer
A GT4088 compressor specs are
64.7mm inducer
88mm Exducer
Turbine specs are
GT4088R= 77mm inducer 78 trim
GT4088= 77mm inducer 84 trim
Different # of blades on the wheels too, they are just totally different unlike a GT4294 and GT4294R which are identical except for being BB and NON BB
63.5mm Inducer
88mm Exducer
64.7mm inducer
88mm Exducer
Turbine specs are
Re: gt4088 vs. gt4088r (Boostfed.com)
Well maby you can help me then, here is my current set up:
B18c1 sleeved 84mm
CP pistons
Manley turbo tuff rods
P&p head
supertech valves, spring
ITR cams
I am looking for at least 650 whp with a red line of 9k. What would be a better selection for my applcation?
B18c1 sleeved 84mm
CP pistons
P&p head
ITR cams
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boost fed ls »</TD></TR><TR><TD CLASS="quote">Well maby you can help me then, here is my current set up:
B18c1 sleeved 84mm
CP pistons
P&p head
ITR cams
I am looking for at least 650 whp with a red line of 9k. What would be a better selection for my applcation?</TD></TR></TABLE>
Definately get the GT4088R or even the GT4094R IMO
B18c1 sleeved 84mm
CP pistons
P&p head
ITR cams
markvqwerty
01-05-2005 07:45 AM
