Switching between saturated and peak and hold?
Old Dec 12, 2003 | 12:29 PM
Hoodwinked's Avatar
Default Switching between saturated and peak and hold?
Hi all,
I currently have DSM 450s wired up with a resistor box. My question is, I am getting Hondata s100b system and I want to get some RC 550cc injectors along with it. First off, do peak and hold injectors and saturated injectors function the exact same, besides a lower impedence. Second, I know the DSMs have a warm start issue, but is that the resistor box doing that? or the actual injectors? I heard its from the resistors getting too hot. So should I just get some P&H 550s or saturated and run it like Honda wants me to. I guess my question is will I see a difference between P&H and saturated? thanks
Old Dec 12, 2003 | 05:35 PM
Hoodwinked's Avatar
Default Re: Switching between saturated and peak and hold? (Hoodwinked)
ttt
Old Dec 12, 2003 | 08:08 PM
LiLOtaku's Avatar
just get the saturated rc550 injectors. That way you won't have to worry about putting in a resistor box. The only thing you'll have to modify is your injector clips.
if you plan on keeping the resistor box, then just get peak and hold injectors.
Old Dec 12, 2003 | 08:19 PM
quikB18B's Avatar
Default Re: Switching between saturated and peak and hold? (LiLOtaku)
The peak and holds will require a resistor box, just spend the extra $ and get the saturated. In the end they will cost the same because of the cost of a resistor box, not to mention the saturated are drop in.
Old Dec 13, 2003 | 09:01 AM
Nfurno's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LiLOtaku &raquo;</TD></TR><TR><TD CLASS="quote">just get the saturated rc550 injectors. That way you won't have to worry about putting in a resistor box. The only thing you'll have to modify is your injector clips.</TD></TR></TABLE>
Old Dec 13, 2003 | 12:33 PM
allablur's Avatar
Default Re: Switching between saturated and peak and hold? (Nfurno)
wait doesnt he already have the resistor box if hes using dsm? i say go a little bigger for room to grow i was gonna get 550s but am gonna get 880s instead just in case
Steeve_Civic
Dec 4, 2011 10:11 AM
columbushatch
Jan 17, 2009 11:08 AM
lowtegsr
Jan 14, 2008 01:25 PM
deucedeuceEK
Oct 30, 2007 04:35 PM
Sassafrass
Oct 9, 2004 09:58 PM
