B20 vtec fresh bluid leaking headgasket?
ok i have a GE sleveed block OEM HG Arp headstuds! k i started my car today started up amazing then i noticed a oil leak coming from under the plastic cam cap vtec solenoid region! i have reseached and found many people saying check distrib o ring, cam cap and vtec solenoid gaskets i know for a fact that it is coming from that headgasket but can a headgasket fail in less than 5 min?
i had great oil pressure i am positive the gasket is up! i used new dowel pins and made sure th rivets where off the matting surface blocked decked and head milled and all oil and coolant passages lined up
i used arp moly lube and torqued them to 75 ft. lbs!
so what could be the reason for this it makes no sense??? please help?
r u 100% percent sure that its not ur camseal leaking.....every B-series honda motor ive seen leaks around the front left cam seal...
positive i found out that since my block was decked and head milled that the dowel pins need to be shaved down some so its apart so ill have it back together tomorrow!
has anyone else had this problem?
can you not read sorry to be a ***** but i stated that!
i think the oil gally bronze allen head plug that is recessed on the heads matting surface could be loose
im going to take it off and pressure test it with oil! new head gasket on the way be here on monday i will keep you posted!
i had the same prob with my dowel pins on my ls vtec i shved mine but still have a overheatin prob thermostat is good only overheats when you rev it up no leaks on coolant hoses any where no smoke unless you rev it to 4000 or higher and it only comes out from engine bay. I have a cometic headgasket and my b 16 head has been decked .040... Help me out some one plz..... This is t he 6th time i have pulled this head off. any info on this e-mail me at Jcvtec@yahoo.com
Thanx alot
Thanx alot
fv8s
Aug 27, 2010 08:48 AM
XkjeldorX
Apr 18, 2005 04:33 PM
