Oil Leaking Problem
Old Dec 20, 2004 | 11:49 AM
colombian linx's Avatar
Default Oil Leaking Problem
Engine: 99 GSR
Problem: Leaking Oil from the the corner of block to the Left of the Header
Ive replaced the Head Gasket and put in ARP headbolts, and its steal leaking, could it be the headbolts werent tightned right? could some one help me?
Old Dec 20, 2004 | 02:15 PM
notstock93's Avatar
Default Re: Oil Leaking Problem (colombian linx)
Cam seal and/or VTEC solenoid.
Old Dec 20, 2004 | 04:07 PM
the vtec solenoid is leaking but that is getting fixed i have the gaskets already, its coming from the corner of the headgasket, the same spot it was leaking last time, its where the headgasket goes on and all the way to the left of the header
Old Dec 20, 2004 | 04:48 PM
notstock93's Avatar
Default Re: (colombian linx)
I have the same leak. My VTEC solenoid is trickling down and pooling around the headgasket tab. My engine has about 5k on it, so I doubt its the HG.
Check the cam seal as well.
Old Dec 20, 2004 | 04:53 PM
_BEN_'s Avatar
It's probably your cam seal. I've seen this happen to my own car and friends.
The best way to narrow it down just in case it is not the cam seal would be to get a can of brake or carb cleaner and spray down the oil (it will just wash the oil away like magic).
Then take your car for a romp around the block and let vtec engage. Then pop your hood and there should be a small amount of oil coming from the leak and you will be able to pinpoint it.
Old Dec 20, 2004 | 05:45 PM
86si's Avatar
Default Re: (notstock93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by notstock93 &raquo;</TD></TR><TR><TD CLASS="quote">I have the same leak. My VTEC solenoid is trickling down and pooling around the headgasket tab. My engine has about 5k on it, so I doubt its the HG.
Check the cam seal as well.</TD></TR></TABLE>
Same here except my 92 GSR has 212k miles on it
Old Dec 20, 2004 | 09:33 PM
PrettyLude's Avatar
check the cam seal
Old Dec 21, 2004 | 09:42 AM
Ok thanks thats what im going to do
cibao2ner
13
Nov 30, 2011 03:56 PM
romeo_f
Apr 7, 2011 10:44 PM
del sol1658
Mar 4, 2008 12:04 AM
sirrjibbalott
Feb 18, 2006 11:52 AM
DXsiRII
Oct 20, 2003 07:55 PM
