Ethanol?
Old Sep 16, 2007 | 02:23 PM
DA6mike's Avatar
Default Ethanol?
Is it safe to run B18C5 on Ethanol?
Old Sep 16, 2007 | 06:54 PM
Padawan's Avatar
Darth ModerVader
Default Re: Ethanol? (DA6mike)
Ethanol as in an ethanol blend (e.g., E85) or straight ethanol? Are you talking about an otherwise stock B18C5?
Old Sep 16, 2007 | 08:41 PM
ForceFed Motorsports's Avatar
Do you even PLEBE R8?
Is your car built to handle E85? If not then no, cars are manufactured only to handle 10% ethonol unless stated otherwise.
Old Sep 17, 2007 | 04:47 AM
King V's Avatar
Default Re: Ethanol? (ForceFed_Motorsports)
Either way, E85 (which is 85% ethanol, hence it's name) or straight ethanol is not recommended unless the proper conversion is made for it. You need alcohol specific injectors and pump, you would need to re-tune it to run on alky since the BTU rate of ethanol is different than gas, you would need to change out the O-rings and seals since alcohol eats rubber. Lots of work.
Old Sep 17, 2007 | 10:50 AM
DA6mike's Avatar
Default Re: Ethanol? (200kCivicSI)
OK thx a lot
Psychoteen101
Sep 6, 2010 10:06 AM
projekt-sol
Feb 4, 2008 06:16 AM
gsrtpower
Nov 19, 2007 12:29 PM
NAEH2NA
Apr 10, 2007 08:08 AM
88crxvtec
Apr 22, 2003 06:11 PM
