head gasket removal
Old Sep 16, 2007 | 10:21 AM
integraRS-T's Avatar
Default head gasket removal
I've searched around and couldn't find jack so here's my thread,got a cometic mls hg,arp studs and a skunk2 im sitting around cause i couldn't afford to pay to get it installed lately so i decided to do it myself, but before i get started i got a few questions,and please correct me if im wrong,i need to put motor at tdc. before i start,how do i get the timing belt of? what should i use to clean excessive dirt like carbon build up and i don't want to mess my timing up since that's my daily driver ,any input is greatly appreciated.
Old Sep 16, 2007 | 11:44 PM
SLO Sol's Avatar
Default Re: head gasket removal (integraRS-T)
to get the Timing belt off you loosen the Tensioner pulley and yes you are correct the motor and the head must be at TDC
Old Sep 17, 2007 | 09:32 AM
MR_FIX_IT's Avatar
Default Re: head gasket removal (D-money 92si)
by a helms, or if ur tight for cash, a haynes, it will tell u everything u need to know
Old Sep 17, 2007 | 11:58 AM
CerealKiller's Avatar
Default Re: head gasket removal (MR_FIX_IT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MR_FIX_IT &raquo;</TD></TR><TR><TD CLASS="quote">by a helms, or if ur tight for cash, a haynes, it will tell u everything u need to know</TD></TR></TABLE>
x2, but I think he means BUY
or save up some cash and have a shop do it.
Old Sep 17, 2007 | 12:26 PM
Default Re: head gasket removal (inlineaddict)
i dont know what helms is but i do have haynes book and a cd bout integras but the way they do it is by taking off a lot of parts when some friends of mine did it much easier
Old Sep 18, 2007 | 09:36 AM
MR_FIX_IT's Avatar
follow the book......as u go u will find short cuts or steps that u might be able to over look but for the most part do as they say........its better to take longer and do it right then to skip every thing and screw it up......besides the more u take off, the more u learn about
Old Sep 19, 2007 | 01:50 PM
92civicx's Avatar
for the less fortinate... http://www.hondahookup.com/manuals/ sign up. now you got helms
da_bseries
Aug 13, 2008 07:27 PM
touandcim
16
Mar 25, 2008 01:31 AM
niceguyjp2183
May 9, 2006 02:51 PM
Ls91sI
Aug 4, 2005 04:13 AM
Piston_Honda
12
Feb 21, 2002 06:18 AM
