BIG PROBLEMS
Old Sep 15, 2007 | 02:52 PM
obd1_crx's Avatar
Default BIG PROBLEMS... LOTS OF SMOKE
ive got a D15B7 bottom end and block with a D16A6 head on it and it SMOKES like hell. i ran a compression check on each cylinder. i got 140 to 150 lbs across it. ive went throught 2 sets of spark plugs in 10 miles. theyre turnin black right off the bat. anybody know what might be wrong?
Modified by obd1_crx at 8:31 PM 9/16/2007
Old Sep 15, 2007 | 06:38 PM
obd1_crx's Avatar
Default Re: BIG PROBLEMS (obd1_crx)
any help would be appreciated guys. this is my daily driver. my family car. i need to get it back running
Old Sep 15, 2007 | 06:44 PM
VtecSyndrome's Avatar
Valve stem seals, piston rings to name a few
Old Sep 15, 2007 | 07:42 PM
obd1_crx's Avatar
Default Re: BIG PROBLEMS (VtecSyndrome)
i thought maybe the rings to but i did a compression check and it was between 140-150 lbs. im not sure if the valve seals are any good though.
Old Sep 15, 2007 | 07:47 PM
SIred91's Avatar
Rainman
Do a wet test as well. Mine all check out at 145/150 all across, but add a teaspoon of oil and the numbers shoot up into the 160's
Old Sep 15, 2007 | 08:10 PM
obd1_crx's Avatar
Default Re: BIG PROBLEMS (SIred91)
IM LOST ON WHAT TO DO NOW. ive got good compression so im guessing its something in the head makin it smoke.
Modified by obd1_crx at 8:34 PM 9/16/2007
Old Sep 16, 2007 | 04:35 PM
obd1_crx's Avatar
HELP PLEASE
youryanyou
Apr 5, 2010 08:14 AM
Terry_shum
May 1, 2004 05:50 PM
RABBIT9
Jun 2, 2003 04:35 PM
1fastdc2
Jan 5, 2003 07:47 AM
gsr stuie
Apr 23, 2002 08:03 PM
