Spring Pin Help
Old Sep 15, 2007 | 02:34 PM
tx95excoupe's Avatar
Default Spring Pin Help
I am trying to put my shift extension back on and i have the old spring pin. Can i just reuse it or do i have to go to get a new one? And if i do where do I get one at? When I Get one how easy is it to reinstall it.
Old Sep 15, 2007 | 02:48 PM
fdavie's Avatar
Default Re: Spring Pin Help (tx95excoupe)
Honda reccomends replacing it - it's only a few bucks, might as well, especially if you had the original one on there. But it probably won't make a difference if you reuse it.
Its about as easy to get on as it is to get off. I'd reccomend using a c-clamp to help get it in - tighten the clamp around the pin, hit the clamp with a hammer, retighten, repeat. Worked better than just a hammer for me. Just make sure its a cheap clamp that you'll never need again. Harbor Frieght FTW!
Old Sep 15, 2007 | 03:03 PM
Default Re: Spring Pin Help (fdavie)
Where can i get a new one? Do i have to go through the Honda Dealership or can i just go to autozone or something for one?
Old Sep 15, 2007 | 03:05 PM
Ex-Eg-Driver's Avatar
Replace that bitch. I have used a used one when putting back on a shift linkage and theres a big *** difference. Get a new one from Honda. For like $2.
Old Sep 17, 2007 | 08:57 AM
Default Re: (JayKayNidas)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JayKayNidas &raquo;</TD></TR><TR><TD CLASS="quote">Replace that bitch. I have used a used one when putting back on a shift linkage and theres a big *** difference. Get a new one from Honda. For like $2.</TD></TR></TABLE>
what kind of difference do you notice, because i had to reuse the old one...i couldnt get one at 5pm on saturday..so i had to reuse it, and so far i dont see a difference.
Old Sep 17, 2007 | 09:02 AM
Archidictus's Avatar
Unceasing Measure
Default Re: (tx95excoupe)
The tighter the spring pin, the less slop there is in the shifter.
Old Sep 17, 2007 | 09:05 AM
Syndacate's Avatar
Default Re: (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">The tighter the spring pin, the less slop there is in the shifter.</TD></TR></TABLE>
Yeah, that's why I replaced mine when I swapped trans's.
I really have no clue why so many people have a problem with this thing .
Old Sep 17, 2007 | 10:02 AM
Default Re: (Syndacate)
well so far i dont notice a difference in shifting.
Old Sep 17, 2007 | 10:04 AM
Unceasing Measure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tx95excoupe &raquo;</TD></TR><TR><TD CLASS="quote">well so far i dont notice a difference in shifting.</TD></TR></TABLE>
If you put the same pin in the same linkage, it's going to be the same as it was before you replaced anything If you install a new spring pin - one that hasn't been compressed by thousands of miles of driving - it'll probably tighten up the shifter a bit and keep it from wobbling around as much when in gear.
Old Sep 17, 2007 | 11:54 AM
Mista Bone's Avatar
D Tranny Guru
I've never replaced mine, but have one on hand, 5 more coming.
BTW 88-95 = &gt;$1 8x20mm spring pin
Old Sep 17, 2007 | 11:55 AM
Unceasing Measure
Default Re: (Mista Bone)
I vouch for Bone
kylefrags
Honda Civic (2006 - 2015)
Mar 27, 2018 06:34 PM
thebluecrx
16
Apr 24, 2011 07:34 PM
BDogggUT34
Feb 11, 2005 03:46 PM
ZaksZCrex
Dec 26, 2003 05:22 PM
gsr squirrel
Aug 29, 2001 04:06 PM
