D15b not going into vtec, no engine codes.....
Old Sep 15, 2007 | 12:38 PM
DougNuts's Avatar
Default D15b not going into vtec, no CEL.....
What could cause a D15b with p28 ecu to not go into VTEC? I had my car dyno'd this week and found out that it's not going onto the big lobes.
The car has not had a check engine light since I wired VTEC 2 years ago.
The car seems to run well.
The car runs a solid 12.8 to 1 A/F ratio, slightly rich due to the p28 mapping, but ok.
The car was up to temp during dyno pulls.
This car is very well taken care of, I just need to figure out why my power peak was at 5050rpm. What checks does the ECU do that would keep it from going into VTEC but wouldn't throw a CEL light?
Thanks,
Doug
Old Sep 15, 2007 | 01:27 PM
ddd4114's Avatar
Default Re: D15b not going into vtec, no CEL..... (DougNuts)
How's your oil?
I assume your speedometer, tachometer, and coolant temperature guage work?
Old Sep 15, 2007 | 02:15 PM
DougNuts's Avatar
Default Re: D15b not going into vtec, no CEL..... (ddd4114)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ddd4114 &raquo;</TD></TR><TR><TD CLASS="quote">How's your oil?
I assume your speedometer, tachometer, and coolant temperature guage work?</TD></TR></TABLE>
Everything on the car works great. The car has a full fill of Mobil 1 synthetic. I give this car the best I can. It's not my daily driver.
Old Sep 15, 2007 | 02:51 PM
ddd4114's Avatar
Aside from a mechanical failure, I'm stumped.
You can hook a 12V source to the solenoid and listen for the click.
Old Sep 15, 2007 | 03:21 PM
DougNuts's Avatar
Yeah, looks like I'll have to wire up one of those vtec lights to see if everything electronic is working. If it all is, I'll have to look into mechanical issues.
Old Sep 16, 2007 | 05:41 AM
DougNuts's Avatar
Bump
Old Sep 16, 2007 | 06:29 AM
instrument's Avatar
helms manual, follow the troubleshooting guide.
Old Dec 28, 2007 | 10:54 AM
DougNuts's Avatar
Back to the top. I still haven't figured this one out.
Again: No CEL, Vtec doesn't work, D15b never opened up, P28 ECU
Old Dec 28, 2007 | 11:06 AM
jadugartir's Avatar
Default Re: (DougNuts)
oil pan not dented?
Old Dec 28, 2007 | 11:15 AM
DougNuts's Avatar
Default Re: (jadugartir)
Yes, it was. I beat it back out a bit and it's still the same. I have one in perfect shape, but I need to get a gasket for it. I also have an oil pressure gauge, but I still need to get a pillar pod for it.
skiracer8148
10
Feb 10, 2007 07:52 AM
dc4drewH
Jun 6, 2005 08:01 AM
tallguy
15
Mar 29, 2005 10:36 PM
acdracing
Dec 13, 2004 06:13 PM
