does vtec work at different rates
just looking for an answer.someone told me that vtec works different if the cars not running right.for example if the check engine light is on the vtec could be weaker than if the car was running perfect.can vtec run at diff %'s or is it all or nothing.
Re: does vtec work at different rates (skiracer8148)
also, if you don't have enough oil pressure (will be detected of the oil is under MIN, or MAX), then you don't have VTEC...
it has 7 safetys...first was mentioned...
2. also there is water temp. that must be over 70°C! (not sure if the temp. is right?!)
3. you must go faster than 13km/h or 8mph!
4. clutch must be released!
5. no CEL! (or no engine error codes)
6.
7.
6.
7.
Re: does vtec work at different rates (KLiK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KLiK »</TD></TR><TR><TD CLASS="quote">also, if you don't have enough oil pressure (will be detected of the oil is under MIN, or MAX), then you don't have VTEC...
6.
7. </TD></TR></TABLE>
Depends what the cel's are. And I think its 20 mph
6.
im not having no problems with my car,but i was just wondering.idk about the 20mph thing because i used to have vafc and it lights up when vtec engages and it would light up if u rev it when parked
Re: (skiracer8148)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skiracer8148 »</TD></TR><TR><TD CLASS="quote">im not having no problems with my car,but i was just wondering.idk about the 20mph thing because i used to have vafc and it lights up when vtec engages and it would light up if u rev it when parked</TD></TR></TABLE>
i have a chipped p30 tuned with crome. i removed the speed check and now vtec engages when i rev the car when parked up. completely pointless,but you can clearly hear it enagaging,its kinda cool............in a not so cool kinda way....
Re: (egsir2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by white ex »</TD></TR><TR><TD CLASS="quote">It either works or it doesn't.</TD></TR></TABLE>
Yes, let's get this off right.
VTEC is 100% BINARY
It is either ON, or OFF.
There is NO middle ground. No "weak" VTEC, etc., either on or off.
Your friend that told you this is a ricer .
VTEC is 100% BINARY
Re: (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate »</TD></TR><TR><TD CLASS="quote">
ive been seeing more and more of "those we dont speak of" lately....i remember when i got into this there werent that many...why cant those days return...
Semper Fidelis
Re: (TurboB16aEG)
It depends on the CEL, I've had CEL's for secondary O2 and MAP and still had vtec, but those are the only 2 CEL's I have ever had
Re: (skiracer8148)
VTEC it's not supposed to run on no output...the problem is that around 7-8000rpm inertial forces on the cilinders become dominant!! that means that it could easily get over-reved...
2SlammedDC2:
well that is beacuse the VTEC doesn't need the O2 sensor imputs in VTEC...and it can run without MAP, 'cause VTEC is predefined with maps!!
2SlammedDC2:
