Watercooler Project ??
Old Sep 15, 2007 | 07:03 AM
overrr's Avatar
Default Watercooler Project ??
Hi,
where can i find information about building a watercooler similar to the pictures bellow, also what kind of water pump, corer, pipes and all parts needed and where can i find them.
thanks
Old Sep 15, 2007 | 10:08 AM
Garage 808 Hatch's Avatar
Default Re: Watercooler Project ?? (overrr)
are you talking about an air to water intercooler?
i run a 12v harbor freight pump, works awesome. and a PWR 6x10 barrel intercooler. they are pretty straight foreward, just finding places for the pump, tank, IC, and the lines.
Old Sep 15, 2007 | 07:18 PM
granturismonut2's Avatar
Default Re: Watercooler Project ?? (Garage 808 Hatch)
I'm running a PWR 6x10 Barrel Intercooler as well, using a Jabsco water pump. Also if this is going to be driven on the street a heat exchanger might be considered. I can post a pic or too if you need
Modified by granturismonut2 at 6:21 PM 9/16/2007
Old Sep 15, 2007 | 11:05 PM
Default Re: Watercooler Project ?? (granturismonut2)
ya, i have my water cell in the cabin, as well as the pump. might want to consider a drain valve as well to aide in draining to add new ice between runs.
Old Sep 17, 2007 | 11:05 AM
overrr's Avatar
thanks guys, on that photos i posted, what is that wastegate doing in the air to water intercooler ? what is the vacuum conected to?
The car is going to be for track only.
Old Sep 17, 2007 | 11:07 AM
overrr's Avatar
if i need to build a custom size core how can i do it ?
Old Sep 17, 2007 | 11:13 AM
FEDDC's Avatar
you need a smaller intercooler core and build an enclosure around the core which will let you run water through it to cool the flowing air into the engine. these intercoolers can be much smaller and still be able to run and flow high hp.
pwr makes pre-fabbed air to water coolers.
hope your setup goes well.
if you need to ask any questions feel free to pm me and i will be able to point you in the right direction..
Old Sep 17, 2007 | 11:16 AM
HickamHatch's Avatar
Default Re: Watercooler Project ?? (FEDDC)
what is a good size core for 700 hp
Old Sep 17, 2007 | 09:04 PM
.RTErnie's Avatar
Default Re: Watercooler Project ?? (HickamHatch)
check out precisionturbo.net they list hp ratings as well as core sizes... that should give a good idea.
Old Sep 17, 2007 | 09:33 PM
Alchemist's Avatar
Default Re: Watercooler Project ?? (.RTErnie)
What are the advantages/disadvantages from air/water vs. air/air???
Old Sep 20, 2007 | 05:15 AM
overrr's Avatar
why are they using a tial wastegate on the core ?
Old Sep 20, 2007 | 11:20 AM
50-50's Avatar
Advantages/ Disadvantages
Air/Water
Pros:
- Better efficiency = cooler air charge
- cooler air charge = more power
- shorter IC piping = faster spoolup
- flexible location
- Water can be replaced with fuild with better heat coeffiecient
Cons:
- Higher cost compared to Air/Air
- Higher maintenance cost
- Complexity
- Weight
Air/Air
Pros:
- Low cost
- Low weight
- Zero to Low maintenance
Cons:
- Must be mouted to take maximum advantage of air flow through it
- Much lower efficiency
- longer possible IC piping
Old Sep 20, 2007 | 12:25 PM
ebydrc's Avatar
Banned
Default Re: Watercooler Project ?? (50-50)
air to air cannot cool below ambient, whereas the water-air can
Old Sep 20, 2007 | 06:30 PM
Default Re: Watercooler Project ?? (ebydrc)
^^ exactly, my air to water beads condensation on the outside of it when i turn the pump. when have you ever felt an air to air at 37ish degrees while running??
Old Sep 20, 2007 | 07:50 PM
im thinking thats the Tial 50mm BOV, not wastegate.
Old Sep 20, 2007 | 10:04 PM
SlowReaction's Avatar
Its a tial 38mm gate on the intercooler or maybe a 44.
Old Sep 20, 2007 | 10:41 PM
RACEPAK's Avatar
arnt these pumps noisy?
Old Sep 21, 2007 | 10:14 PM
Default Re: Watercooler Project ?? (RACEPAK)
the pump is kind of noisy, but nothing that using some form of insulator between the pump and the mounting surface doesn't solve. I used a 1/4 thick rubber mat.
Old Sep 22, 2007 | 12:23 PM
Heres mine
Old Sep 22, 2007 | 03:18 PM
I like that alot
what is that one the passenger side infront of the radiator and the charge piping?
not a very good pic of mine \/
Old Sep 22, 2007 | 03:53 PM
MidShipCivic's Avatar
Awesome watery cushion impact!
Old Sep 22, 2007 | 05:26 PM
G2K's Avatar
G2K
Default Re: (MidShipCivic)
you are correct about the wastegate on the intercooler, its a 38mm tial, and it serves a certain purpose, but I don't know if the owner/crew cheif of the car want me to tell but you can contact Jeromie Hicks with Eggum Racing on here, he goes by FMUNK. He might tell you the use of the wastegate.
Old Sep 22, 2007 | 05:45 PM
A pop off valve probably ....
Old Sep 23, 2007 | 08:47 AM
on mine there's the BOV on the bottom of the piping, and then that big black thing is an air scoop to get air through the radiator.
gsrt
Dec 13, 2012 07:49 AM
85
Feb 17, 2010 01:40 PM
PRO1
Oct 1, 2009 08:02 PM
9seccivicsi
Sep 23, 2004 03:02 PM
ScottEK
Jul 20, 2004 10:19 AM
