small air/water intercooler pump?
Old Feb 15, 2010 | 10:07 PM
85's Avatar
85
Default small air/water intercooler pump?
I'm looking for a compact water pump for a air water intercooler setup. engine will only be making about 200HP so i don't really need anything ridiculous. Its on a motorcycle so im hoping to find something small.
Old Feb 15, 2010 | 11:34 PM
rmcdaniels's Avatar
Default Re: small air/water intercooler pump?
I've used the Johnson CM10 circulating pump for that application. It's small, silent, ball bearing, no vibration, magnetic drive (no seal to go bad), and low current. The Syclone/Typhoon guys have mostly switched to this type of pump, which is where I learned about it. Here's a link to where I bought my last one:
http://store.hamiltonmarine.com/brow...6-/4,6386.html
Old Feb 16, 2010 | 09:05 AM
Alfa Turbo's Avatar
Yikes, I am sure the pump will do the job, though I did not see the specs on the link provided but yowser, that is pricey!
I have used bilge pumps with good success. 8GPM / 500GPH for $25-$35. They last years and I run them constant on.
Old Feb 16, 2010 | 09:38 AM
85's Avatar
85
AWESOME! yeah, I was turned away from the price of the other pump. where are you finding these $25-35 pumps? im seeing $200, 300 range
Old Feb 16, 2010 | 10:37 AM
welfarepc's Avatar
i picked up a small 360gph bilge pump from a boating store for $35
Old Feb 16, 2010 | 05:31 PM
Alfa Turbo's Avatar
I am using a Mayfair Marine pump, just do a search they are readily available. They make them in ALL kinds of styles so you have lots of install options.
http://www.lmgtfy.com/?q=mayfair+marine+bilge+pump
Old Feb 16, 2010 | 11:18 PM
DailyDriverCivic's Avatar
I used this same 360GPH Rule Bilge pump in many applications. It goes for under $23 shipped, and works great. I have been mounting them in my coolant reservoir for my IC systems, as they arent really an inline type of deal. Here is an ebay link to one:
http://cgi.ebay.com/Rule-360-G-P-H-B...item3ca9862a1f
Here is one I have for a project I am working on so you can see the actual size:
Old Feb 17, 2010 | 11:58 AM
twkdCD595's Avatar
Bosch pump from a 03/04 cobra works pretty well on a friends setup.
Old Feb 17, 2010 | 01:40 PM
boostedcivicsir's Avatar
Mr. Badwrench
i dont know if the 07- up shelby is the same pn, but thats another option.
gsrt
Dec 13, 2012 07:49 AM
PRO1
Oct 1, 2009 08:02 PM
overrr
Welding / Fabrication
23
Sep 23, 2007 08:47 AM
9seccivicsi
Sep 23, 2004 03:02 PM
poorguy
Sep 11, 2004 05:21 PM
