A/C compressor
Old Sep 14, 2007 | 06:31 AM
PhilMac's Avatar
Default A/C compressor
93 honda civic si 1.6l (stock) 240,000 miles
I am having a lack of power when the a/c is on it bogs then picks up.
Is this a sign that i need a new compressor.
I checked to see if it is seesing up, and checked the belt out for cracks but it isn't.
thanks for looking!!!!
Old Sep 14, 2007 | 06:34 AM
crazyguy's Avatar
Default Re: A/C compressor (PhilMac)
yeah it is most likely your ac compressor seizing up..
Old Sep 14, 2007 | 06:44 AM
PhilMac's Avatar
Default Re: A/C compressor (crazyguy)
Is changing the compressor easy med. or hard to do..
Old Sep 14, 2007 | 06:47 AM
crazyguy's Avatar
only 2 bolts to take out the high and low pressure ac lines on compressor...disconnect the power plug..unscrew 4 long bolts..and it is out..pretty staright forward and easy
Old Sep 14, 2007 | 06:49 AM
PhilMac's Avatar
as far as the belts go is there just one i have to worry about
Old Sep 14, 2007 | 06:51 AM
crazyguy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PhilMac &raquo;</TD></TR><TR><TD CLASS="quote">as far as the belts go is there just one i have to worry about</TD></TR></TABLE>
oh there is a adjust bracket and bolt to loose the pulley in order to loose belt..it is pretty straight forward too.
Old Sep 14, 2007 | 06:54 AM
PhilMac's Avatar
Great, Thanks for your help!!!
Old Sep 14, 2007 | 07:35 AM
instructor74's Avatar
unless the system was retrofit to R134 has R12 coolant in it and you will need to take it some where to have the R12 recycled. It is also very expensive to recharge the system with R12 so you will more than likely need to switch over to the new R134
Old Sep 14, 2007 | 08:06 AM
PhilMac's Avatar
Default Re: A/C compressor (instructor74)
I know that R12 was drained out but not vacuumed out completely and was retro fitted to the 134a.
ConanDan
Jul 29, 2007 06:21 PM
mxl360
Jun 16, 2006 10:43 AM
jlamaster
Oct 1, 2004 07:12 PM
bostonegcivic
May 21, 2004 08:41 PM
BoM
Nov 25, 2003 12:49 PM
