RPM? Cluster?
Old Sep 13, 2007 | 06:04 PM
EG-HK's Avatar
Default RPM? Cluster?
Hi everybody, the problem just come out in a few months ago. The RPM needle sometimes point to zero when its idle. Sometimes normal and all the way fine of the RPM when I accelerate. What is this problem? Cluster? or any other things?
Old Sep 13, 2007 | 06:48 PM
EG-HK's Avatar
Default Re: RPM? Cluster? (EG-HK)
Anyone help?
Old Sep 13, 2007 | 08:25 PM
EG-HK's Avatar
Old Sep 14, 2007 | 04:19 AM
k-custom's Avatar
i have a 92 lx and i have the same problem! not sure how to fix it, hopefully someone will help us out man!
Old Sep 14, 2007 | 05:30 AM
Syndacate's Avatar
Default Re: RPM? Cluster? (k-custom)
No, it's not normal, try a known working cluster and see if the problem persists - or plug that cluster into somebody else's car - the plugs are the same on all '92-'95 civics. The tach head is probably going out.
Old Sep 14, 2007 | 05:31 AM
WhiteOnRice's Avatar
It's probably the tach, not the car's actual idle.
Old Sep 14, 2007 | 05:32 AM
Syndacate's Avatar
Default Re: (WhiteOnRice)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WhiteOnRice &raquo;</TD></TR><TR><TD CLASS="quote">It's probably the tach, not the car's actual idle.</TD></TR></TABLE>
Yes, if the car is idling at 0 RPM it's not on .
Old Sep 14, 2007 | 07:15 AM
k-custom's Avatar
anyway it can be repaired? i would like to have my factory tach back but if not ill install a aftermarket tach!
Old Sep 14, 2007 | 08:05 AM
Default Re: (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">
Yes, if the car is idling at 0 RPM it's not on .</TD></TR></TABLE>
Heh, I forgot he said it was at 0 rpm and not irratic.
Chronicsinners
13
Nov 22, 2006 05:11 AM
EJ1Rider
Feb 16, 2005 06:22 PM
PurpleGsR00
Oct 22, 2002 11:48 AM
