Which Intake Manifold Gasket To Use?
I have a '99 DX that underwent a Y8 manifold swap from a '98 EX
I initially used a Felpro D16Y7 gasket from AutoZone
After the car was fired up, there was a huge intake leak, so I scrapped that gasket and went to buy another one
I then used the same brand D18Y8 gasket which seemed to seal it alot better, but there was still a leak (checked with Carb Cleaner). I decided to just seal it with RTV silicone and forget about it. But now the leak is back
I now want to buy an OEM or a Hondata gasket
So my question is
Which one do u recommend, and if i go with the OEM, do i get it for a y8 or a y7?????
So my question is
Go with the Hondata. It's thicker and also non-heat transferable so it will slightly lower your intake air temp! Plus it's like $50 so you can't go wrong.
Get an intake manifold for the 98 Y8, it will block off the injector ports. Also what TB/IAC are you running? If your still running the y7 ecu you wont get a good idle without the 3P IAC.
Well the reason i was asking for what car is because the gaskets are different
Heres the 1st one I used which is like the hondata d series one:
And heres the one that is currently on the car that sealed better than the 1st one (oddly enough this is for a 99-00 EX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">Get an intake manifold for the 98 Y8, it will block off the injector ports. Also what TB/IAC are you running? If your still running the y7 ecu you wont get a good idle without the 3P IAC. </TD></TR></TABLE>
I do have the manifold for a 98 Y8, and i am using my Y7 throttle body with the stock 3 wire IACV
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by greenej8 »</TD></TR><TR><TD CLASS="quote">Go with the Hondata. It's thicker and also non-heat transferable so it will slightly lower your intake air temp! Plus it's like $50 so you can't go wrong.
yea you can go wrong with that... 50 bucks compared to like 20... unless its turbo the fact that its non-heat transferable and thicker will make no difference
</TD></TR></TABLE>yea you can go wrong with that... 50 bucks compared to like 20... unless its turbo the fact that its non-heat transferable and thicker will make no difference
i have a Evolution Industries one of these
if your interested make me an offer i take pay-pal and live in the same state as you!
i also have H&R racing springs 2.5 inch drop honda/acura make me an offer
richard...
Modified by Richard... at 3:58 PM 11/1/2007
richard...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ridin98civic »</TD></TR><TR><TD CLASS="quote">nextgear gasket
hondata will never get a cent from me</TD></TR></TABLE>
EDIT: Evolution Industries sorry!
EX-T
10
May 4, 2014 08:02 PM
FRKWOO
Sep 22, 2009 11:39 AM
949
Apr 7, 2009 08:04 AM
eg2phosizzle
Feb 23, 2006 09:02 PM
