Turbo How to launch?
Ok I have a 95 civic hb with gsr fully build 9:1.1 comp pistons. Im running 24.5/9/13 inch slicks on bogarts. running 12 psi of boost. If I launch at 5000 the car will bog but if i launch at 6000 it will light the slicks up out of the whole until i hit the top of second gear then i wll start catching trackson. best so far is a 12.09@122 mph
1-have you got adjustable front shocks and extremely stiff rears.
2-what tire pressure are you running
3-have you got z-10 or comp engineering traction bars in front
4-do you have a spool/limited slip diff/or open diff
could you please post the whole slip times out of your 12.09@122 mph or best run you have ever had and just kinda list some of the highlights of your turbo setup...
Adi
Other than that try feathering it out of the hole to control wheelspin.
Streetracer, where do ya live in Portland? Huh you must live across the street from me or something!!!!!!! Laterz - Adam
[Modified by JDMspecEG6, 11:51 AM 12/14/2002]
B00STED Si
Mar 11, 2005 04:16 PM
typesguy
Mar 8, 2005 01:22 AM
