Turbo How to launch?
Old Jun 16, 2002 | 04:40 PM
HotRodTeg's Avatar
Default Turbo How to launch?
Ok I have a 95 civic hb with gsr fully build 9:1.1 comp pistons. Im running 24.5/9/13 inch slicks on bogarts. running 12 psi of boost. If I launch at 5000 the car will bog but if i launch at 6000 it will light the slicks up out of the whole until i hit the top of second gear then i wll start catching trackson. best so far is a 12.09@122 mph
Old Jun 16, 2002 | 05:30 PM
speedworks's Avatar
Default Re: Turbo How to launch? (streetracer)
1-have you got adjustable front shocks and extremely stiff rears.
2-what tire pressure are you running
3-have you got z-10 or comp engineering traction bars in front
4-do you have a spool/limited slip diff/or open diff
Old Jun 16, 2002 | 06:25 PM
IVANITR's Avatar
Default Re: Turbo How to launch? (speedworks)
I'd try in between 5k and 6k which leaves 5.5k rpm, see what you can work out from there. I'd try trial and error to find the sweet spot.
Old Jun 16, 2002 | 07:00 PM
Jared's Avatar
What kind of tire pressures are you running?
Old Jun 16, 2002 | 11:39 PM
DLB1994's Avatar
Default Re: Turbo How to launch? (Jared)
u got 2 step
Old Jun 17, 2002 | 02:33 PM
Adi Radoncic's Avatar
On Fire!
could you please post the whole slip times out of your 12.09@122 mph or best run you have ever had and just kinda list some of the highlights of your turbo setup...
Adi
Old Jun 17, 2002 | 06:58 PM
FAST94GSR's Avatar
New User
With that trap speed I estimate you are making about 350 to the wheels. I would start with suspension, what coil rate springs do you have on the rear? Do you have a Quaife LSD or anything like that? Z10 bars would help . What psi are you running in your slicks? I would run it as low as 5 psi and see if that works.
Other than that try feathering it out of the hole to control wheelspin.
Old Jun 17, 2002 | 09:06 PM
paulzy's Avatar
Default Re: Turbo How to launch? (FAST94GSR)
you are running through the traps at 122mph with 12lbs of boost? who's your tuner? Tha'ts good for a a very low 11 or high 10
Old Jun 18, 2002 | 10:32 AM
jinxproof99's Avatar
New User
122 mph in a full interior hatch w/ gsr stock bore is good for at least mid 11's.
Old Jun 18, 2002 | 12:12 PM
Kataku2K3's Avatar
Default Re: Turbo How to launch? (jinxproof99)
Streetracer, where do ya live in Portland? Huh you must live across the street from me or something!!!!!!! Laterz - Adam
[Modified by JDMspecEG6, 11:51 AM 12/14/2002]
AllShowNoGo727
Jun 16, 2011 09:11 AM
christion
Jul 7, 2007 02:00 PM
B00STED Si
Mar 11, 2005 04:16 PM
typesguy
Mar 8, 2005 01:22 AM
DRAGLS
Nov 12, 2001 06:32 PM
