1/4 mile times
Old Nov 12, 2001 | 04:39 PM
DRAGLS's Avatar
Default 1/4 mile times
Went to the track sunday I ran some shitty times for my setup.
94 ls built engine 16psi on street tires and i only got a 13.4 at 109 with alot of wheel spin. What do guys think of those times. What do u think its capable of.
Old Nov 12, 2001 | 04:45 PM
BoM's Avatar
BoM
Default Re: 1/4 mile times (DRAGLS)
damn ur running 16psi? what turbo do u have?
how much hp? and whats your suspension and wheel setup?
your times looks alright, ur trap speed is high, but your time can be lower
how was your 60'? psi tires?
Old Nov 12, 2001 | 04:48 PM
DRAGLS's Avatar
Default Re: 1/4 mile times (bommiE)
Best 60' was a 2.1 tire pressure was at 14psi
Old Nov 12, 2001 | 05:11 PM
PureTeg420's Avatar
obviously traction is your problem. If you had slicks or maybe even drag radials, you'd be in twelves easy
Old Nov 12, 2001 | 05:16 PM
tararan's Avatar
thats kinda slow for a ls turbo on 16 psi i think... but likeyousaid you got lots of wheel spin.. that suck.. i think you are capable of running 12s.... unless something wrong with the turbo or leaks on the piping... late
Old Nov 12, 2001 | 05:56 PM
DRAGLS's Avatar
Default Re: 1/4 mile times (tararan)
Like i said i had wheel spin 1st,2nd,3rd all three gears before she would hook up
slicks next time low 12's high 11's
Old Nov 12, 2001 | 06:04 PM
DIRep972's Avatar
Smarter than you
109 traps is definitly good for 12's.. What turbo kit u running? if its drag3 i would be expecting closer to 112mph in the 1/4
Old Nov 12, 2001 | 06:32 PM
Rob03Pro5's Avatar
Default Re: 1/4 mile times (DIRep972)
I'm not sure if wheel spin was really that much of a factor.. unless the tires were just busting loose like crazy in 2nd and 3rd gears. Your 2.1 60' is great for street tires. Maybe you should shift at a lower rpm for 2nd and 3rd
HamiltonRex
Jun 11, 2006 07:10 AM
efgarage
May 3, 2005 10:58 AM
95c1v1cs1
Jun 9, 2003 04:11 PM
integraracer94
May 28, 2002 03:59 PM
Rah Rah
Aug 13, 2001 09:33 PM
