swapping CTR motor into del sol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbosol18 »</TD></TR><TR><TD CLASS="quote">what do i have to change or modify to put an OBD2 98 CTR motor into my OBD1 93 del sol?
all you need is the motor of coarse and a p28 or p30.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbosol18 »</TD></TR><TR><TD CLASS="quote">wont i have to change the engine hardness since im not using obd1 anymore?
if my memory serves me correctly, no. the engine harness will hook up to your existing harness. you will have a couple of bare plugs and that's because obd2 motors use more sensor that obd1 cars don't have. but if you use a obd1 (dohc vtec) ecu you should be fine.
oh, and i believe you might have to change out the injectors, but i'm not sure. search it up, your bound to find something.
yeah well regardless i will be using 450cc injectors with my turbo kit..but yea i kno some stuff will not be used on the obd1 hardness
compwc18
Jun 17, 2004 02:59 PM
