Hamp filters
Old Sep 10, 2007 | 09:42 PM
99fbpem1's Avatar
Default Hamp filters
There is only 1 hamp oil filter right? 1 version i mean
Old Sep 10, 2007 | 09:52 PM
nighttrain33's Avatar
Default Re: Hamp filters (95civicdx)
From searching the web, that is all I have found.
-Shane
Old Sep 10, 2007 | 10:02 PM
99fbpem1's Avatar
Default Re: Hamp filters (nighttrain33)
yeah me too, just didn't want to buy 10 filters and then find out they don't work on my car.
Old Sep 10, 2007 | 10:08 PM
Did you look at their site? For $12 might as well try it and see.
-Shane
Old Sep 10, 2007 | 10:18 PM
eg6sir-s's Avatar
there are 3 types...
standard, wide, short
Modified by eg6sir-s at 11:59 PM 9/10/2007
Old Sep 10, 2007 | 10:20 PM
99fbpem1's Avatar
Default Re: Hamp filters (eg6sir-s)
differences?
Old Sep 11, 2007 | 04:04 AM
Skunk.Werks's Avatar
All honda filter threads are the same, only difference is can size
Old Sep 11, 2007 | 08:50 AM
99fbpem1's Avatar
Default Re: Hamp filters (Skunk.Werks)
what would the different sizes do i mean
Old Sep 11, 2007 | 09:32 AM
MonkeyBoy668's Avatar
In theory the filter inside should be different, the larger the canister the larger the surface area of the filter inside it. Sometimes though the larger canister simply hides the fact that the same size filter is being used as a smaller model. Marketing wonks suck.
All things being equal, larger filter elements should yield slightly lower oil pressure, and smaller filters slightly higher.
Over a certain oil pressure the bypass valve inside the filter lets oil flow through unfiltered, so I don't entirely understand why you'd want to make that window of filtration smaller, at least for a daily driver.
In Googling while looking for a discussion of Hamp filters I came across this link.
Old Sep 11, 2007 | 11:12 AM
forcefedferio's Avatar
Default Re: Hamp filters (MonkeyBoy668)
the RSX oil filter from hamp when used on a b-series will bump up oil pressure by 5 psi with no added restriction.
info from Hamp and InlineFour.com ^
Old Sep 11, 2007 | 12:14 PM
Malakai's Avatar
questions but y would u want higher oil pressure?
or lower for that matter?
Old Sep 11, 2007 | 01:59 PM
Default Re: (Malakai)
because VTEC works mostly off oil pressure, i'm trying to think of the best way to put this....think of it as a squirt gun, more pressure the more water force you will have, this is better for higher revving engines that need the oil and need it quickly.
Old Sep 11, 2007 | 02:15 PM
Malakai's Avatar
ah ha tru enuff thanks!
mhax
Jul 13, 2014 06:30 PM
petec59
Honda Civic (2006 - 2015)
16
Apr 19, 2007 12:21 PM
Renegade
Feb 22, 2006 07:00 AM
oldskool_rex
Jul 26, 2003 12:50 PM
Flux
Mar 24, 2002 07:43 PM
