Which Oil Pan Gasket for 1999 EX?
There are two shown in the Honda parts catalog. One is a thin tube shaped gasket and the other is a flat, wide gasket. I It shows the flat gasket has been discontinued, but I don't want to replace my oil pan just to put in the tube type gasket. Please take a look.
Illust.
No. Part Number Description Reqd.
Qty. Year Model List Price Our Price Into Cart
001 11000-P2E-810 BLOCK ASSY. (DOT) 1 1999 CIVIC 1727.77 1459.96 Qty:
002 11106-PE0-300 BOLT, SEALING (14MM) 1 1999 CIVIC 1.17 .91 Qty:
003 11126-PK1-003 BOLT, SEALING (22MM) 2 1999 CIVIC 1.92 1.49 Qty:
005 11200-P2J-000 PAN, OIL 1 1999 CIVIC 235.44 183.61 Qty:
006 11221-P2J-000 PLATE, BAFFLE 1 1999 CIVIC 30.30 23.63 Qty:
008 11251-P2J-000 GASKET, OIL PAN 1 1999 CIVIC 18.73 14.61 Qty:
009 11301-P2F-A00 COVER, R. SIDE 1 1999 CIVIC 38.07 29.69 Qty:
009 11301-P2A-000 COVER, R. SIDE 1 1999 CIVIC 38.07 29.69 Qty:
010 11311-PM3-000 CVR, BREATHING PORT 1 1999 CIVIC 3.35 2.61 Qty:
011 11910-P2A-000 BRKT, ENGINE MOUNT 1 1999 CIVIC 29.40 22.93 Qty:
012 30530-P2M-A01 SENSOR ASSY., KNOCK 1 1999 CIVIC 153.04 119.83 Qty:
013 37240-P2F-A01 SWITCH, OIL PRESSURE (FASCO CONTROLS) 1 1999 CIVIC 8.00 6.24 Qty:
013 37240-PT0-014 SWITCH, OIL PRESSURE (TEC) 1 1999 CIVIC 8.00 6.24 Qty:
013 37240-PT0-023 SWITCH, OIL PRESSURE (DENSO) 1 1999 CIVIC 8.00 6.24 Qty:
014 90001-PM3-003 BOLT, DRAIN PLUG (28MM) 1 1999 CIVIC 9.78 7.63 Qty:
015 90007-PM6-003 BOLT-WASHER (11X116) 8 1999 CIVIC 8.48 6.62 Qty:
016 90008-PM3-000 BOLT 1 1999 CIVIC 3.57 2.78 Qty:
017 90008-PM6-003 BOLT-WASHER (11X131) 2 1999 CIVIC 8.48 6.62 Qty:
018 90008-PR3-000 BOLT A 1 1999 CIVIC 3.92 3.06 Qty:
020 90009-PY3-000 BOLT, PLUG (14MM) 1 1999 CIVIC 4.82 3.76 Qty:
021 90041-PA5-000 BOLT, STUD (6X28) 4 1999 CIVIC 3.08 2.41 Qty:
021 90042-PR3-000 BOLT, STUD (6X28) 4 1999 CIVIC 2.88 2.25 Qty:
022 90041-P01-000 BOLT, STUD (12X40) 2 1999 CIVIC 6.67 5.20 Qty:
024 90401-PR4-000 WASHER, SEALING (28MM) 1 1999 CIVIC 2.47 1.92 Qty:
025 90703-PE0-000 PIN, DOWEL (18X22) 1 1999 CIVIC 4.80 3.74 Qty:
026 90715-PC6-000 PIN, DOWEL (13X20) 9 1999 CIVIC 2.82 2.20 Qty:
027 91214-PAA-A01 OIL SEAL (80X100X10) 1 1999 CIVIC 15.42 12.02 Qty:
028 94050-06080 NUT, FLANGE (6MM) 10 1999 CIVIC 0.15 .12 Qty:
029 94109-14000 WASHER, DRAIN PLUG (14MM) 1 1999 CIVIC 0.28 .22 Qty:
030 94301-06100 PIN A, DOWEL (6X10) 2 1999 CIVIC 0.98 .77 Qty:
031 95701-06012-08 BOLT, FLANGE (6X12) 7 1999 CIVIC 0.78 .61 Qty:
032 95701-06016-08 BOLT, FLANGE (6X16) 2 1999 CIVIC 0.65 .51 Qty:
033 95701-06018-08 BOLT, FLANGE (6X18) 8 1999 CIVIC 0.65 .51 Qty:
033 95801-06018-08 BOLT, FLANGE (6X18) 8 1999 CIVIC 0.65 .51 Qty:
034 95701-06025-08 BOLT, FLANGE (6X25) 4 1999 CIVIC 0.73 .57 Qty:
http://www.hondaautomotivepart...L+PAN
Thank you.
Illust.
Thank you.
Thanks.
I think I found the solution; I read the flat is for non-vtec and the tube is for vtec and vtec-e. When I look in the catalog for a Civic DX, they show the other gasket and pan is in stock. So I guess they just use the same drawing for a few models and do not list part of it for specific models.
it depends on which pan you have. y8/y5 (VTEC(e)) has an aluminum pan, which uses the thin gasket, y7 (non-VTEC) has a steel oil pan and uses the wide flat one.
ringgold
18
09-20-2004 04:28 AM
11251p2j000, 11301p2a000, 1999, 30530p2ma01, 99, aluminum, assy, civic, honda, number, oil, pan, part, sensor, tub
