head opinions
Old Sep 10, 2007 | 06:38 PM
grg3135's Avatar
Default head opinions
hi all, i was thinking of buying an ek with a gsr swap. the block is lightly built too, but whats more imporant is the head. the ek comes with a b16 head, here are the given specs
- Milled .020, ported and polished
- Supertech valves, 3 angle valve job
- Dual valve springs
- TI Retainers
- Skunk 2 st.2 cams
- SRR cam gears
- ARP head studs
- AEM fuel rail
- Blox IM
I had bought a built gsr head recently for a different build which fell through which had the following specs
- Milled 0.020, ported and polished
- Toda Spec B cams
- Skunk2 cam gears
- Toda valvetrain, dual valvesprings and retainers with stock valves
- BDL fuel rail
- Type R Intake manifold (modded to fit gsr head)
Just looking to get some opinions on which head would be better all together or would it be worth it to frankenstein it from both heads. open to opinions. Also, the ek comes with 440s but that might be overkill for NA? i also have a set of 330s, what do you guys think?
Modified by grg3135 at 9:45 AM 9/11/2007
Old Sep 10, 2007 | 07:23 PM
doood's Avatar
been there done that
Default Re: head opinions (grg3135)
toda b's have a better midrange. s2s2's have a better top end. what do you want?
Old Sep 10, 2007 | 08:49 PM
grg3135's Avatar
well, i suppose id go mid. Im just going to be dd-ing it and dont need the high end as much. ill think about it
Old Sep 11, 2007 | 06:49 AM
grg3135's Avatar
anybody else?
Old Sep 11, 2007 | 08:19 AM
JdelMsolG's Avatar
Default Re: (grg3135)
toda ftw!
Old Sep 11, 2007 | 08:36 AM
grg3135's Avatar
but which head would make more power? the b16 or gsr?
Old Sep 11, 2007 | 08:40 AM
Jakester9500's Avatar
id rock the toda one
Old Sep 11, 2007 | 09:12 AM
cartune network's Avatar
Default Re: (Jakester9500)
the gsr will make more power right off the bat because it has a smaller combustion chamber that will inturn bump up your compression ratio.
gsr head=higher compression over b16 head.
Old Sep 11, 2007 | 09:33 AM
grg3135's Avatar
ok cool, so prob just put the gsr head on as it sits and then and sell the built b16? what about the injectors? 440s or 330s for an NA build?
Old Sep 11, 2007 | 09:40 AM
well what r u going to put in the gsr head? i wouldnt go any lower than 330cc injectors. im using 440's on my itr but im not using anywere near all of them.
Old Sep 11, 2007 | 09:49 AM
grg3135's Avatar
well, for now im just going to leave it as is with the IM/Cams/springs&retainers/p&p. it would be going on a 81.5mm gsr block with 12:1 pistons, arp rod bolts, and acl bearings
Old Sep 11, 2007 | 09:50 AM
its up to u man. if u plan on building the head and porting it u know its gonna cost alot of money. u might be better off just using the b16 head being that its already built. u know?
Old Sep 11, 2007 | 09:54 AM
grg3135's Avatar
the gsr head is ported and polished as well, actually the only thing "less built" on the gsr head is the stock valves, but still has toda springs and retainers
Old Sep 11, 2007 | 11:31 AM
grg3135's Avatar
anybody else? general consensus seems to be leave the gsr head as is and take off the b16, correct?
Old Sep 11, 2007 | 03:30 PM
grg3135's Avatar
ttt
Old Sep 12, 2007 | 10:10 AM
grg3135's Avatar
nobody else has any input?
DeltaCharlie2
Sep 25, 2012 09:05 AM
DeltaCharlie2
Sep 21, 2012 09:33 AM
Muckman
Apr 13, 2011 09:31 AM
Invisible01GSR
Aug 17, 2004 12:33 PM
AutoMan
Aug 3, 2003 03:15 AM
