gsr into A EM1
ok dropped gsr in and not ive run into this into a 00 SI motor is obd2
giveing the car gas it boggs out.
parts used Si harness Si computer, used jumper with obd1 gsr comp samething
cars running hella rich plugs were black as hell
it does not back fire at all idles smooth as you roll on the throttle it bogs and will not rev past 2.5k rpm.\
any ideas hit me up
swap dizzy gsr to Si on problem still there \
cam timing is dead on
only thing i can think is compression. but the thing idles so smooth im not leaning towards that.
has a skunk2 inake mani and 65mm thottle body.
sprayed carb cleaner around to find any vacuum leaks no change in idle, spray into throttle bore stalls out.
thinking it might be a blockage in the fuel return line to the tank
used Si regulator and gsr regulator same problem
does 99-00 teg injectors used a resistor box?
get at me
__________________
any ideas hit me up
get at me
__________________
No all the Tegs/Civics 94-up didn't use a resistor box so you're OK on that. The car wouldn't even start if you're impedance was too low as the injectors wouldn't fire.
Have you calibrated the TPS on the 65mm t/b? And are you positive there's no internal vacuum leak say from the IACV to the inside of the throttle body bore? Some manifolds only have a very thin wall seperating the IACV passage from the main throttle bore.
well the throttle body is a edle brock so i did nothing to it honestly cuz they come with all new sensors.
i spray carb cleaner around the thottle body intake mani and no change in idle at all, sprayed into thottle bore and she stalls out.
this issue has taken most of the swap time up so im kinda pissed
Might be time to get a milti-meter and a shop manual, start testing the sensor outputs on that new engine and see of they're all working right. I know sometimes people complain of broken sensors on swaps they get.
haha, I know others have been tricked by those 2 connectors also...never happened to me so I wasn't familiar with the symptoms. Glad you are ripping up the road again. How is it compared to the old B16?
slob20ef
Mar 15, 2012 07:31 AM
PnX-R
Jan 14, 2002 01:56 PM
