Help on map sensor probs on motor swap. please
Old Jun 16, 2002 | 09:59 AM
turboex's Avatar
Default Help on map sensor probs on motor swap. please
Ok my friend has a 96 prelude and he had the sohc motor. so he pulled the motor and got a 92 h23 dohc. and converted the car to obd1 with a harness and is now using the obd1 ecu. the problems we have are that no matter what ecu is hooked to the car it throws the map sensor code. ok the wires did get pulled from the sensor plug so we put them back in a tried ever possable option. and still the car runs kinda bad. the idle is at 200rpm and its kinda jerky. once the car is over say 20mph it runs great and has alot more power than the sohc. any ideas out there? I hooked a scanntool to read the map sensor but it always stays a 49hg... and never anything diffrent. this is with the car not running. however my honda crv stays at 27hg.. when the car is not running. so im kinda confused. thanks for any help!
Old Jun 16, 2002 | 10:55 AM
prelude1897's Avatar
Default Re: Help on map sensor probs on motor swap. please (turboex)
Did you make sure you put the right plug in? Some of the plugs look the same, so they will beable to plug into different spots....Just check the harness to see if they are hooked up in the right spot.
Old Jun 16, 2002 | 12:28 PM
turboex's Avatar
Default Re: Help on map sensor probs on motor swap. please (prelude1897)
Yep all the plugs are in the right spots. thanks any other ideas?
bad23591
Dec 9, 2012 11:33 AM
illassek9
Jul 29, 2008 11:07 AM
Rukusmasta2
Jul 26, 2008 01:16 AM
D15JDMARIO
Feb 18, 2007 01:52 AM
RudeLude95
Apr 14, 2005 11:30 AM
