corrosion inside my distributor
i had this problem since i bought the car. Corrosion build up on the 4 terminal inside the cap. this make my car misfire and lose power. Couple of years later i bought a msd kit, that include the box,coil and cap. same problem. i bought different caps and rotor but still the same ****.
im thinking about getting rid of the msd system and buy a new distributor. I have to clean the corrosion every week so the car can run in better conditions.
let me know what you think
Is a 2000 si
Is a 2000 si
mine used to misfire every so often because the seal to the distributor cap was too thin, even though it came from Honda. I used some dielectric grease on the seal and haven't had any problems with it. I stored the car outside last winter for 5 months and it started right up after that time.
Try that and then see if that works.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carloselpavo »</TD></TR><TR><TD CLASS="quote">well you said you were using msd cap & rotor. MSD parts are copper. if so, keep the cap and change the rotor for a steel looking one.</TD></TR></TABLE>did that already but same ****.
AndyD
Dec 22, 2014 03:13 PM
2camsaam
Oct 3, 2002 12:34 PM
