da9 just put motor in and it wont start
Old Sep 9, 2007 | 01:07 PM
crxsteve's Avatar
Default da9 just put motor in and it wont start
i just putt aboosted b18a1 in my car from a b16a and i hooked everything up
went to go start it and it just turned it has spark and fuel presscould it be the fuel press is to low it's at 36psi and i have h22 injectors
could it bee the fuel rail is cloged or something??
i am lost
it only ran a code 6 and thats a temp senc
thanks for any help
Old Sep 9, 2007 | 01:23 PM
crxsteve's Avatar
Default Re: da9 just put motor in and it wont start (crxsteve)
bump
Old Sep 9, 2007 | 03:22 PM
TIMMY4TOES's Avatar
hAVE YOU CHECK ALL THE GROUDN? if i put money you forgot to ground something.
Old Sep 9, 2007 | 04:44 PM
DB1_559's Avatar
he u tried a compession test ? have u ever took the head apart?
Old Sep 11, 2007 | 07:34 PM
crxsteve's Avatar
Default Re: da9 just put motor in and it wont start (DB1_559)
sad to say it but my batt didn't have enough volts and the motor wasn't spin fast enought
i got a new batt and it started rite up just now i am running 4 slow blink and 3 fast blinks on my ecu codes
Old Sep 11, 2007 | 08:58 PM
GSR-TRBO-DA's Avatar
that is code 43
Old Sep 11, 2007 | 09:21 PM
Rikter's Avatar
Quick google search found:
Code 43 is a fuel supply or o2 sensor circuit malfunction. Only thing I have ever seen with this code is a bad o2 sensor. It will cause a poor running condition usually until the light comes on and then the computer removes the o2 sensor readings from its equations and runs off a set parameter list. Not very efficient. Replace the O2 sensor and see what happens. Make sure to erase the code when you replace the o2 sensor
-Rik
Old Sep 12, 2007 | 08:06 AM
crxsteve's Avatar
Default Re: (Rikter)
it's a brand new o2 sencor
could it be cuz i had to make the wire longer and i put the wire links in there???
it would make it not read rite
burfy
14
Nov 16, 2011 07:53 AM
Keeper1343
Dec 17, 2007 11:17 AM
Elbowpunk
Feb 3, 2006 06:50 PM
DC2EGHB
13
Mar 18, 2004 05:44 AM
FoRmerLyMentAL
Mar 8, 2003 05:09 PM
