engine/ecu harness
Old Jun 16, 2002 | 05:45 AM
ITRmike98's Avatar
Default engine/ecu harness
If i put a B18c1 engine (GSR) into a '98 civic EX, will the GSR ecu/engine plug into the Civic herness or will i need to use a GSR harness or maybe some other kind of conversion??
Old Jun 16, 2002 | 10:38 AM
Charlie Moua's Avatar
Default Re: engine/ecu harness (gsr mike02)
If the motor is a 96-00 GSR it will be plug and play.
If your GSR motor is a 94-95 motor then you will need a Skunk2 ecu conversion harness. This harness wil then make the swap plug and play. They are usally anoutmnd $250
Old Jun 16, 2002 | 03:08 PM
ITRmike98's Avatar
Default Re: engine/ecu harness (Charlie)
thanks
v8killaz
May 15, 2010 03:07 PM
Tunez
Oct 30, 2008 12:51 PM
boostincoupe
Sep 10, 2006 08:34 AM
alltech
May 18, 2002 10:28 AM
mickey513
Apr 8, 2002 07:59 PM
